Old 07-25-2014, 03:24 PM   #1
Devain's Avatar
1989 32' Excella
Helena , Alabama
Keeler lock problems
I have two issues I'm currently working through with this door lock. The door doesn't seem to close all the way. It seem to stick out between an 1/8 to 1/4 inch all the way around. It was worse at the top and bottom until I worked on it with a 2x4, now its about uniform. There doesn't seem to be an adjustment on the locking bar. The door jam inset also has no adjustment. Any ideas?
The jam inset it enclosed to keep the water out that may make it past the seal.
The other issue I have is that the lock was gummed up so I took it apart and did too good of a job greasing it up so when I close the door too hard the door latch falls and locks me out. A piece of tape holds it up at the moment. I'm thinking I should take it back apart and wipe it out?
Below is what I mean by door jam inset. I find half the battle in locating stuff is finding the correct name.
Devain is offline   Reply With Quote
Old 07-25-2014, 03:34 PM   #2
Attachment 217367
From your description, it sounds like the striker bolt is bad worn.
When you took the lock apart, what did you do with the small ball and spring that controls the inside vertical locking shaft?
When that ball is not properly adjusted or is missing, then there is nothing to keep the door from locking itself every time you close it.
Not good.
Keeler lock inop from outside. Ben4762 Doors & Locks 3 07-29-2011 08:27 PM
'85 Excella keeler door lock assembly handyman1425 Doors & Locks 0 01-02-2011 08:59 AM
Keeler lock assy replacement, '87 AS tambram Doors & Locks 3 08-10-2010 08:40 AM
Keeler lock interior handle sovereign66 Doors & Locks 3 06-26-2009 11:19 PM
Keeler Entrance Door Lock Silverhobby Doors & Locks 1 04-08-2008 08:44 PM
