Old 07-29-2011, 01:37 PM   #1
Ben4762's Avatar
1989 32' Excella
Lawrenceville , Georgia
Keeler lock inop from outside.
I have a Keeler lock on my 1989 Excella. The lock will not let me open the door from the outside, but opens from the inside. Anyone here on the forum had this problem?
Name:   Keeler lock for Airstream.jpg
Georgia Unit # 32
Top of Georgia
Ben4762 is offline   Reply With Quote
Old 07-29-2011, 03:33 PM   #2
Originally Posted by Ben4762 View Post
I have a Keeler lock on my 1989 Excella. The lock will not let me open the door from the outside, but opens from the inside. Anyone here on the forum had this problem? Attachment 136259
A lock replacemnt is the fix.
Keeler Brass is out of business.
Old 07-29-2011, 07:09 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Lots of info on Keeler locks...Airstream Forums - Search Results)
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 07-29-2011, 08:27 PM   #4
Airdaddy's Avatar
1975 31' Sovereign
1969 27' Overlander
Wichita , Kansas
I had the same problem on my 75 A/S. Called around and like your model there is no new fix. I called around for a few days and then finally I found a local lock guy that knew how to replace the worn part that was needed. Works great and I didnt have to cut up my door to install the updated system available. Also not to long ago, maybe two weeks, there was a door lock like yours on the for-sale items. might look into seeing if they still have it on line.
Airdaddy
Wichita, Kansas
Airdaddy is offline   Reply With Quote
'67 Caravel Door lock Question vonzellen Doors & Locks 14 11-29-2011 01:26 PM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 06:34 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
