Old 02-02-2012, 01:38 PM   #1
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Keeler Lock Exterior Handle
I have a new 'braced' handle and I'm ready to swap out the old cracked one. I looked for any info on how to do it and what to expect but I couldn't locate any, I'm not a very good "web detective"... Looks like just 3 screws on the inside of door and 2 in jamb by the latch. But I'll just bet there is more to it than just removing the screws and pulling out the lock for handle service. Any hints before I go into this "blind" are appreciated!
captmatt is offline   Reply With Quote
Old 02-02-2012, 02:09 PM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Remove the 3 inside screws first. The inside handle will pull off. Then remove the 2 in the door edge. There is probably some sealant that will bind the outside to the door, but should not be a problem. While its out clean it and lube it good. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 02-07-2012, 12:51 PM   #3
1986 29' Sovereign
Wichita , Kansas
Replacement hanle
Where did you get the "braced" handle? I have the same problem and have been looking for a replacement handle. As the reply from NOREEN said removing the lock assembly is very easy (5 screws), the harder part is driving out the roll pin that holds the handle in place. I used a long bolt the same diameter as the pin and that worked farily well.
jama68 is offline   Reply With Quote
Old 02-07-2012, 01:12 PM   #4
1981 31' Excella II
New Market , Alabama
I just made a new handle for mine. There was a guy on here making them but he did not respond to my IM's so I made my own. Here is a prototype drawing. I had to make some tweeks to this and have not made those updates yet. The final version is on my trailer. It works like new.
Perry
Old 02-07-2012, 01:26 PM   #5
1981 31' Excella II
You remove the three screws on the backing plate on the inside and then remove the two bolts in the door frame. You can knock the roll pin out with a 1/4" dowel or flat head punch. There is a spring in there that is a little bit of a pain to get back in so pay attention how it fits in there or better yet take a photos of it before removal. If you get frustrated it will work fine without the spring in there.
Perry
Old 02-07-2012, 02:15 PM   #6
1986 29' Sovereign
Wichita , Kansas
Hi perryg114 you must be a MUCH better metal worker than I am! Your drawing looks very good. You interested in making another one to sell? If so how much, I would be interested.
Old 02-07-2012, 02:23 PM   #7
1986 29' Sovereign
Wichita , Kansas
Perryg another thought, if you don't want to post prices you can e-mail me at jama68@gmail.com. Thanks.
Old 02-08-2012, 06:34 AM   #8
1981 31' Excella II
Here are some photos of the finished product.
Perry
Old 02-17-2012, 09:37 AM   #9
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Vintage Trailer Door Parts
Old 02-17-2012, 10:05 AM   #10
1981 31' Excella II
$285 you could by a basket case trailer for that.
Perry
Old 03-08-2012, 07:58 PM   #11
dctrapp's Avatar
los angeles , California
Keeler Lock Handle
Anyone know where to buy one these days. Mine just broke...
dctrapp is offline   Reply With Quote
Old 03-08-2012, 09:03 PM   #12
Maniacal Engineer
barts's Avatar
Menlo Park , California
Out-side Door handle for lock. 380346 [380346] - $49.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-09-2012, 04:38 AM   #13
1981 31' Excella II
I can make you one of the Keeler Brass type handles which is usually the part that breaks. This is just the flapper thing that you grab to open the door which is usually the part that breaks.
Perry
Old 03-09-2012, 05:30 AM   #14
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Perry
Pan down page a little, just handle is like $30....
Keeler lock inop from outside. Ben4762 Doors & Locks 3 07-29-2011 08:27 PM
Exterior door lock replacement 1986 Excella Sov1969 Doors & Locks 3 07-25-2011 06:34 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
