Old 07-06-2012, 08:03 PM   #43
1960 24' Tradewind
Riverside , California
Sorry but the lock pictured is a Trimark lock, usually about $50 at most RV Dealers, there is a knock off from a company called FasTec that's only about $36 The FasTec is a M/N 43610-00-SP
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 07-07-2012, 04:59 AM   #44
1993 30' Excella
1976 25' Tradewind
Flushing , Michigan
My lock--the same as pictured in #29--has Tri/Mark cast in the back of it.
steve46 is offline   Reply With Quote
Old 07-07-2012, 05:04 AM   #45
1993 30' Excella
1976 25' Tradewind
Flushing , Michigan
I first purchased the FasTec #43610, however it requires the door modification I described in #37, thus my search for a repair solution to the Tri/Mark
Old 07-07-2012, 05:30 AM   #46
Originally Posted by Inland RV Center, In View Post
The lock pictured in post # 29 above is a KB.
Keeler Brass.
They are no longer in business.
Oops. Wrong lock name.
Old 07-21-2012, 06:27 AM   #47
1993 30' Excella
1976 25' Tradewind
Flushing , Michigan
The repaired lock is now installed and works very well, actually works much better since the repair and some lubrication!
Old 04-18-2013, 03:57 PM   #48
1986 27' Sovereign
Nixa , Missouri
Images: 21
Keeler handle replacement
Hi All,
I recently had the Keeler lock handle on my 86 Sovereign break and tried to order one from VTS but they are out of stock on the item. I then was able to source one from forum member Perry. It looks and works great. I am very happy with it. I'm trying to post pics for the first time so we'll see how it goes.
Barry
bweldon is offline   Reply With Quote
Old 04-18-2013, 08:21 PM   #49
1986 27' Sovereign
Nixa , Missouri
Images: 21
For some reason my pics dont let you click to enlarge them. The first is the original & second is the one that replaced it.
Barry
Old 04-18-2013, 08:58 PM   #50
1986 27' Sovereign
Nixa , Missouri
Images: 21
Trying again to post pics that can be resized.
Barry
Old 04-18-2013, 09:03 PM   #51
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Barry
OK, what are the dimensions in pixels of the images that you are trying to post?
Where are you trying to post them from?
Vaughan
Old 04-18-2013, 11:16 PM   #52
1986 27' Sovereign
Nixa , Missouri
Images: 21
Dimensions are 124 X 166
Size is 3949 bytes
I'm not great with computers. The first time I posted pictures, they came out of the file on my mac that I keep all my Airstream info. The second time, I pulled the photos over to iPhoto then imported them from there. Any help is appreciated.
Barry
Old 04-18-2013, 11:58 PM   #53
1983 34' Excella
1967 24' Tradewind
Images: 32
Size is 3949 bytes
Barry
124 X 166 is what is showing up. I'm guessing that these are thumbnails of larger images. You need to locate the larger image and upload that. (No larger than 1600 for its largest dimension, though)
I don't particularly care for iPhoto so I don't use it much. The photos on my iPhone show up automagically so that's mainly what I use iPhoto for. I rarely use the camera in my iPhone though, preferring to use my Sony Alpha 100. I only mentioned this because I've been flopping around in iPhoto trying to figure out what might give the 124 X 166 images. No luck. Maybe someone who uses iPhoto more can chime in.
Although I did get to see some iPhone photos that I hadn't seen in a long time.
I'm not going to be much help right now. If I figure something out, I'll get back in touch. Otherwise, see if you can locate the larger images.
Vaughan
Old 07-21-2013, 11:21 AM   #54
deale , Maryland
Perryg114 - If you are still making the handle for people, am interested in price. Please send info to shaperdd@yahoo.com
shaper is offline   Reply With Quote
Old 07-21-2013, 01:30 PM   #55
1981 31' Excella II
New Market , Alabama
Yes I still have them. I will email you about the details.
Perry
Old 08-12-2013, 08:45 PM   #56
1983 34' Limited
Christchurch , Canterbury
Hi Perry, I'm keen to get a replacement handle for my Keeler lock. Do you still have them?
Tony Burton is offline   Reply With Quote
Keeler lock inop from outside. Ben4762 Doors & Locks 3 07-29-2011 08:27 PM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 06:34 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
