Old 05-09-2012, 08:43 PM   #29
Alden Miller's Avatar
1993 34' Excella
, Maryland
Ok, here's the photo of my lock. Now the experts can tell me what I have so I can find parts if needed.
1993 34' Excella 1000
2005 Dodge Ram 3500 Diesel
(No it doesn't have a HEMI in it)
Alden Miller is offline   Reply With Quote
Old 05-10-2012, 05:41 AM   #30
1981 31' Excella II
New Market , Alabama
That is not the Keeler Lock. I would talk to Andy at Inland RV and see if he can ID that lock for you.
Perry
Old 05-10-2012, 07:53 AM   #31
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
That looks much like mine. Mine is a smoothe finish and no key in the handle. I have a crack in the handle and am looking to find a replacement before the dreaded break occurs.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 05-10-2012, 09:09 AM   #32
1981 31' Excella II
Scroll up a page or tow and see if yours looks like the ones earlier in the post?
Perry
Old 05-10-2012, 09:35 AM   #33
retired USA/USAF
2001 30' Excella
Perry, I need to get another look at mine to be sure. I should just take a pix and be done with it. I'll do that ASAP.
Roger in NJ
TAC - NJ 18
Old 05-10-2012, 08:30 PM   #34
retired USA/USAF
2001 30' Excella
I took a photo today but having trouble with the computer. Will not read the card so I can't get it posted. Will try again later
Roger in NJ
TAC - NJ 18
Old 06-21-2012, 06:59 AM   #35
1993 30' Excella
1976 25' Tradewind
Flushing , Michigan
Alden, did you ever identify your handle/lock mechanism positively? I need to repair or replace mine on a 1993 Excella 30'. Either the casting or the pin broke at the bottom where it swivels/hinges. It looks--from my memory--just like yours, unfortunately the Airstream is 200 miles away in storage for a week. I want to have the right part when I return. Thanks. Steve
steve46 is offline   Reply With Quote
Old 06-25-2012, 05:16 AM   #36
1993 34' Excella
, Maryland
I did not. The bottom pin of the handle kept falling out after 10 or 20 uses. It should have been a tighter press fit. A little dab of silicone underneath it has kept it from dropping out so for now it's working.
-Alden
Old 07-05-2012, 04:30 PM   #37
1993 30' Excella
1976 25' Tradewind
Flushing , Michigan
Here is what I have learned (slowly)--I was able to find a replacement lock/handle--item #43610, made by FasTec Industrial Corp (FIC) as the original mfr (Tri/Mark) is gone. The new one will fit, but as it has a deadbolt feature, I’d have to drill out the door end for the deadbolt and relocated mounting screw (and I was 200 miles from my shop with real tools). So I began a search for a solution to the weak link in my original--the plastic bushing with a shoulder that the roll pin fits into--no such luck. As a last ditch attempt, I stopped at Ace Hardware (my 5th or 6th establishment to try) and the helpful hardware guy said “ sure I have what you need”. Skeptical, but very interested, I followed him to what he called a “plumbing compression fitting”--that is not what I’d call it, but whatever. Picture a thin walled brass bushing with a shoulder and hole all the way through--very similar to a 22 caliber shell casing with a hole at the primer end. I bought two--the roll pin fit very well--took them home and cut to length, put a bit of grease in the end, recrimped the roll pins to be tight enough and reassembled. After a bit of wiggling and lubrication, it now seems to work just fine and I will install later in the month when I return to the Airstream. I am reasonably sure this design is superior to the plastic bushing. After I reinstall, then I will return the ~$40 replacement unit and have only $1 in the actual repair. Hopefully this may help someone else in similar circumstances.
Old 07-05-2012, 04:53 PM   #38
Tri-mark is still very much in business.
We purchase from them every month, up to and including 2 weeks ago.
Old 07-06-2012, 07:03 AM   #39
1993 30' Excella
1976 25' Tradewind
Flushing , Michigan
Thanks for correcting my impression/statement. I was told they did not supply the handles/locks anymore and replacement parts were not available--thus my search for a solution elsewhere--it seems that perhaps I should have done further research, too.
Old 07-06-2012, 10:35 AM   #40
Steve.
There is a lock kit available that replaces the Keeler Brass lock.
Old 07-06-2012, 12:57 PM   #41
1981 31' Excella II
So what is the official name of the lock he has Andy?
Perry
Old 07-06-2012, 04:32 PM   #42
Perry
The lock pictured in post # 29 above is a KB.
Keeler Brass.
They are no longer in business.
Keeler lock inop from outside. Ben4762 Doors & Locks 3 07-29-2011 08:27 PM
Exterior door lock replacement 1986 Excella kellywood Doors & Locks 3 07-25-2011 06:34 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
