Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 07-03-2014, 11:30 AM   #1
astrocaver
1986 25' Sovereign
Denver , Colorado
Keeler door lock
I am trying to repair a Keeler door lock used on 80's trailers. The common defect is a broken exterior pull. Does anyone have the body from this lock. I need the bolt plate assembly. It is a flat plate that is wrapped around the bolt and rivited. I am trying to avoid the door patch fix that is the only other solution.
astrocaver is offline   Reply With Quote
Old 07-03-2014, 12:26 PM   #2
Keeler Brass has been out of business for many years.
Wish you luck in finding what you need.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 07-03-2014, 12:47 PM   #3
1981 31' Excella II
New Market , Alabama
I bet your little tabs broke off that actuate the plunger? A machine shop might be able to bend a new piece and rivet it on there. If you just needed a handle I could fix you up.
Perry
Old 07-06-2014, 12:10 PM   #4
astrocaver
1986 25' Sovereign
Denver , Colorado
Keeler lock
After reviewing the options and costs I decided to make my own part. Here is the finished part with the broken one. Made with one sheet of 16 gage steel, drill press, grinder, and lots of filing.
Old 07-06-2014, 12:41 PM   #5
1981 31' Excella II
Good work. I would not have expected one to break there. Usually the tabs break off because the handle breaks and the tabs get stressed.
Perry
Old 07-06-2014, 12:43 PM   #6
airdreamers's Avatar
2008 27' International FB
Venice , Florida
Images: 14
Nice job. You have a talent there. Good luck with the install and operation.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Keeler Lock / Door Handle Boegie86 Airstream Classifieds 1 02-13-2014 03:58 PM
Wanted - keeler exterior door lock 1953pontiac Airstream Classifieds 2 01-06-2014 12:09 AM
Keeler Main Door Lock Repair/Replacement MaxAB Windows, Doors, Locks & Vents 1 12-23-2012 06:14 PM
'85 Excella keeler door lock assembly handyman1425 Doors & Locks 0 01-02-2011 08:59 AM
Keeler Entrance Door Lock Silverhobby Doors & Locks 1 04-08-2008 08:44 PM
