Old 03-11-2008, 09:17 PM   #21
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
We have owned this Trade Wind for 2 years now. Hardly a week goes by that I discover something new about it. Our coach came with a dead bolt. It doesn't have a lock in it so it must have been placed there for additional security of the door flying open in transit. The dead bolt is a good tight fit. No rattle. However the door latch came with no striker and of course the door wasn't snug when closed. I bought the metal striker and it fits fantastic. The door closes with minimum effort and does not rattle. The dead bolt nylon striker is chipped away on the leading edge but doesn't affect the security of the door staying closed. I always believe 'if it ain't broke don't fix it'. Andy, am I correct in understanding this thread that my dead bolt isn't original? Also from what you can tell from my photo that it is best to leave it alone since it works or am I looking to some problems down the road?
Thanks for being in this Forum.
Neil.
Name:	Airstream.Door Latch and suicide Lock 001.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 03-11-2008, 10:37 PM   #22
Neil.
Your moreso describing a 1967 dead bolt that was installed on your door.
Please list the trailer serial number and/or a photo and I can better help you.
You should replace the "nylon striker pocket."
It's only available from us, since we own the original mold.
Old 03-11-2008, 11:17 PM   #23
FreshAir's Avatar
1966 24' Tradewind
The serial # is SO246012. The photo shows the door knob and desd bolt. Pleas tell me your part number for the 'pocket' and I will order one post haste.
Thanks again.
Neil
Name:	Airstream.Door Latch and suicide Lock 002.jpg
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 03-12-2008, 08:06 AM   #24
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Hi Neil.........
I have the exact same dead bolt on my '66 Safari. The actual dead bolt is a round pin that goes into the door frame.
Where did you find the blue block thing that you use to keep the door closed (for extra insurance)?
Thanks!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 03-12-2008, 09:27 AM   #25
Thanks again.
Neil
You indeed have a 66 trailer.
Perhaps I am mistaken about what year Airstream first used that dead bolt.
When it works correctly, you can lock and unlock the deadbolt from the outside, but you can only "unlock" the deadbolt from the inside.
It was called a "travel lock".
That dead bolt has not been available for at least 25 years.
The entrance door locks, are available.
The nylon striker pocket is part # 91377.
Old 03-12-2008, 10:33 PM   #26
FreshAir's Avatar
1966 24' Tradewind
I have placed my order for the 'pocket'. The trailer was advertised and the pink said that it was a '65 when we bought it. After joining this Forum these very knowledgeable members taught me that it was indeed a '66 built in October '65. Of course the Corning windows were a clue too. As for the travel lock mine can be locked and unlocked from both the outside and inside. Obviously it's only purpose is addtional insurance against the door opening in transit. My entry doorlock (knob) works smoothly. What maitainence must I do to keep it that way? I have read several horror stories in this Forum of people finding themselves locked in.
Thanks again,
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 04-28-2008, 05:57 PM   #27
SlvrSt8Steve's Avatar
1967 17' Caravel
Reno , Nevada
Blue Door Block Lock/Shim
Thanks again.
Neil
Neil/Lynn,
Did you make the blue block lock/shim? If so, would you mind tracing the pattern and sending it to me? I've been reading over some of the door lock problems and what I'm experiencing falls some when in between (I guess). I have the round deadbolt pin below the lock/striker plate. Everything seems to work OK, however, due to age and maybe a bit of wear, the door has a good 1/4" gap when closed. I'm in the process of replacing the screen door seal and main door seal, but even this won't make up for the gap. The only reason the gap bothers me is that we've got alot of dust and high wind in NV and all of that just blows right into the trairler when we're hummin' along. Your simple solution has piqued my interest as I don't really feel like moving door hinges around, etc. Anyone care to give me their opinion on the state of the striker plate? Andy? I suppose it is a bit worn and has LOTS of rivets...Thanks, Steve
ID:	59233   Click image for larger version
1967 Caravel
2007 Toyota Tundra
SlvrSt8Steve is offline   Reply With Quote
Old 04-28-2008, 07:30 PM   #28
Originally Posted by SlvrSt8Steve
Neil/Lynn,
1967 trailers used the "nylon" striker pocket, as previously posted.
The nylon pocket was used in all the models from 1964 through 1969.
Using a metal striker pocket for those years, accelerates the wear on the striker bolt, as well as wearing rather fast itself, especially if the running gear is not balanced correctly.
Old 04-28-2008, 07:38 PM   #29
1967 17' Caravel
Reno , Nevada
Andy,
Just checked out your part no. 91337, I guess I should switch the one I have out for a new nylon striker. I'm assuming I would drill out old rivets on existing plate and install new nylon plate with rivets or screws? If rivets, any suggestions for a well-made, all purpose rivet gun and size of rivets most commonly used? Any danger of having too many rivets on the jamb/frame? Sorry for the barrage of questions, I've obviously got a lot of catching up to do...Thanks, Steve
1967 Caravel
2007 Toyota Tundra
Vintage '70s Shower Door and Water Heater Door -- Freebie maccamper General Repair Forum 6 05-15-2009 10:18 AM
Pictures of '64 door striker? 59er Doors & Locks 2 12-03-2007 02:06 PM
Screen door striker Robfike Classic Motorhomes 5 06-03-2006 07:26 PM
Striker Rod for '66 Overlander draftwomyn21 Refrigerators 6 05-21-2006 09:20 PM
Pocket Door vs. Accordion (folding) Door A/S Interior pap Cabinets, Counter Tops & Furnishings 12 03-10-2005 05:40 PM
