04-28-2010, 09:16 AM
1958 22' Flying Cloud
Folsom
Is this deadbolt original or "custom"?
At any rate, it does not work. It is missing the internal part that actually makes it work. It has the same knob on both sides. I assume its kind of a child lock / animal lock or maybe a safety precaution during towing?
04-28-2010, 10:03 AM
Wise Elder
2010 30' Classic
South of the river
Hmm. I vote for, uh, custom.
04-28-2010, 10:09 AM
I believe this was available in 67 and 68. This thread may help.
http://www.airforums.com/forums/f453...light=deadbolt
Regards,
Kevin
William C. Swinney
04-28-2010, 12:01 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
original
66, 67, 68 had those. BUT>>>>>still use a mechanical lock too..the old faithful wood block.
04-28-2010, 01:28 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
I've seen the same lock on lots of trailers of that era...enough to think it is original - or at least standardized option.
Shari
04-28-2010, 11:22 PM
Corona
That was an original "travel lock".
You could lock and unlock it from the outside, but you could only open it from the inside, just in case someone on the outside decided to engage it.
05-05-2010, 05:03 PM
1961 19' Globetrotter
Southern
I have the same trailer as you do and mine has the same lock also
Jill
05-26-2010, 08:19 PM
RGates
1968 20' Globetrotter
Thousand Oaks
I have a Good source for replacement!
I just bought a replacement for my 1968 Globetrotter. You can replace the assembly through Vintage Trailer Supply. They offer either the style with 2 knobs or the one I have, with an exterior knob and an inner handle. The inner handle locks by lifting on it. Very nice, but mine was about 130.00. Yours is about 1/2 that I believe. Be careful to read VTS info re: ordering to assure the correct style, either a short locking rod or a long one dependent on the positioning of the lock on the door. Hope that helps.
Randy Gates
05-27-2010, 07:34 AM
1967 24' Tradewind
Greenville
, South Carolina
"Old faithful wood block" ????
05-27-2010, 08:05 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
Ricky
05-27-2010, 08:57 AM
1966 30' Sovereign
Bethany
Has anyone else had issues with their replacement door handle?
My mechanism is coming loose inside the door. The knob gears will not catch unless pushed toward the trailer. Very annoying. If I need to start a new thread I guess I could.
Cory, Angie, and 'Lucy'
1966 Sovereign International
2003 Black Chevy Silverado w/q-steer
05-27-2010, 09:24 AM
1967 24' Tradewind
Greenville
, South Carolina
Love it!
05-27-2010, 09:28 AM
1958 26' Overlander
Mesa
Gotta love the doohickey!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
06-08-2010, 05:09 PM
Corona
Randy Gates
There is a huge problem with the inside "handle" type lock used in the 66, 67, 68 and 69 trailers.
When your on the inside and need to "slam" the door shut, that inside handle will breaks.
Many hundreds of them took that dive.
