Old 03-07-2014, 12:46 PM   #1
1969 25' Tradewind
Ely , Minnesota
Is there a gasket/seal for a screen door?
I have a 25' 1969 Tradewind. The screen door works fine, except it lets all the Minnesota state birds (mosquitoes) in around its perimeter by the frame. Is there supposed to be a seal or gasket around there or must I just suck it up? If so, what is it called? Thanks.
seismicfish is offline   Reply With Quote
Old 03-07-2014, 01:04 PM   #2
1999 28' Excella
New Orleans , Louisiana
Weather strip!
We were in Jackson Ctr this past summer and bought screen door weather striping. I cleaned the edge of the screen door then stuck it on. It even made the curves on both ends of the top of the door. Looks great! Cost was $6. Looks clean and neat.
badkat is offline   Reply With Quote
Old 03-07-2014, 01:06 PM   #3
cameront120's Avatar
1972 25' Tradewind
My '72 has a foam gasket around its perimeter.
North Vancouver, BC
Old 03-07-2014, 01:12 PM   #4
1969 25' Tradewind
Ely , Minnesota
Most excellent idea for standard hardware store fare. So you put it on the door or the frame? Is it the foam type (thickness?) or the fuzzy bristle type? Thanks for the advice! My hemoglobin level will appreciate it.
Old 03-07-2014, 01:17 PM   #5
1972 25' Tradewind
Mine is the foam type and it is attached to the door. It is probably about 3/8" wide and thickness is probably between 1/8" and 1/4".
North Vancouver, BC
Old 03-07-2014, 01:19 PM   #6
1972 25' Tradewind
Here's a picture (don't mind the sleepy dog).
North Vancouver, BC
Old 03-08-2014, 09:41 AM   #7
1999 28' Excella
Mine is foam also..kinda black or charcoal gray..works great also cut it in 3 pieces. One piece goes from latch area all the way up and around the top to the other side and down. The other is straight across the bottom..last is from latch area down.
Old 03-08-2014, 06:55 PM   #8
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Check out the 1/8 foam at your hardware store.
Ahab is offline   Reply With Quote
Old 03-12-2014, 08:55 AM   #9
The correct screen door gasket is 5/8 inch wide and 3/8 inch thick. It's gray open cell foam.
Airstream parts stocking dealers have it.
You will need 16 feet of it, which costs less than the shipping.
Screen Door Weather Strip TBRich Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 12-17-2011 04:00 PM
Putting a '79 screen door back on the hinges blickcd Doors & Locks 5 09-10-2011 04:11 PM
Broken welds on a '79 screen door blickcd Doors & Locks 4 09-08-2011 06:43 PM
Rear window screen pass through-pet door triterra Windows & Screens 4 07-19-2011 07:43 PM
