Old 05-26-2011, 12:32 PM   #15
bredlo's Avatar
1954 22' Safari
Deerfield , Illinois
Send a message via AIM to bredlo
Originally Posted by pbearsailor View Post
I'm thinking that you are looking at an original H20-2 in there Brad. There are a couple of pics in my thread and Melody Ranch had pics in another thread as well. One thing I see in your video is that the skin around the lock is pop riveted on and it definitely would have been buck riveted originally. Sure looks like that skin has been patched at some point to accomodate the new handle.
-steve
I sure hope so, Steve. Thanks for weighing in.
I agree on the ext: I was already confident no door would've left the factory with anything besides a single sheet of aluminum, and the pop rivets add weight to your conclusion. I believe the interior handle being original as well (mine looks like Toastie's) means they may have just replaced the exterior portion.
bredlo is offline   Reply With Quote
Old 05-26-2011, 12:57 PM   #16
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
We too found several donor locks on eBay when rebuilding our lock. I think we needed to buy two or three partials plus we had the broken one that came on Birdy - then we sent it all out to be re-chromed. A couple of hundred dollars later, we have two complete locks, plus some extra bits & pieces.
"It's a Girl!!!"
By taking all of them apart and comparing bits & pieces, it was pretty easy to see how they work and what was broken on some wasn't on others. Of the three we have, we have two different inside handles (in pics) but they are interchangable. There also are some that the outside hangle is oriented horizontally and others vertically (like ours), these are interchangeble as well.
They can be found...sometimes you just have to have patience and buy it when you see it, not when you need it.
Shari
Old 05-26-2011, 02:07 PM   #17
bredlo's Avatar
1954 22' Safari
Originally Posted by InsideOut View Post
We too found several donor locks on eBay...
...They can be found...sometimes you just have to have patience and buy it when you see it, not when you need it.
Perfect - thanks Shari. It's reassuring to see additional "door gut" photos that look just like mine, and good to know that they come up now and then for N8 and the rest of us.
Having spares of anything that's been out of production for 50 years is a great insurance policy.
Old 05-26-2011, 03:53 PM   #18
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
What you seem to have is the guts for what I call a right hand door in a left hand door. The extra lockset I have is the same as yours.
I moved the door in my Overlander and made it swing the same way as yours seems to. The lock was on the bottom. I talked with Dan at Vintage Campers and he was able to come up with the correct lock set for me. My key will be on the top now.
So long story short, you have the right lockset for the left door.
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is online now   Reply With Quote
Old 05-26-2011, 06:09 PM   #19
bredlo's Avatar
1954 22' Safari
I see what you're saying. In other words, to use this I'll have to position my handle horizontally, as with the lock is on the bottom the handle would be covering it.
Aesthetically I'd probably prefer to have the handle pointing down, but you could argue it's less likely to be broken off being horizontal; I think people would be more likely to twist it down than pull on it.
Old 05-26-2011, 06:54 PM   #20
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
Man, those assemblies are BEAUTIFUL! see, that is why old trailers appeal to us all. The new stuff just cant compare!
Phrunes is offline   Reply With Quote
Old 05-26-2011, 07:53 PM   #21
BradS's Avatar
1957 26' Overlander
Images: 14
You are correct Brad. You could position the handle up and really have a unique trailer. Will you have the new trailer at Alumapalooza?
WBCCI 10289
TAC MN-69
AIR 11240
Old 05-27-2011, 04:34 AM   #22
Arrowstream's Avatar
Columbia , South Carolina
Is this what you're looking for? I have two locksets and one interior handle that came off of a 1947 Spartan.
Both are right hand locks. With your back to the door hinge, the door swings out to the right. That places the plunger and handle to the top.
ID:	130786   Click image for larger version
Arrowstream is offline   Reply With Quote
Old 05-27-2011, 06:04 AM   #23
BradS's Avatar
1957 26' Overlander
Images: 14
Look at the locks that Arrowstream has. It took me a while to find one like his. If you use it on a left hand door the key hole will be on the top and the handle will be on the bottom. I think that this is what you want. The extra lock that I have is the opposite of his
WBCCI 10289
TAC MN-69
AIR 11240
Old 05-27-2011, 09:30 AM   #24
bredlo's Avatar
1954 22' Safari
Wonderful - just sent Arrowstream an email.
Old 06-04-2011, 05:52 PM   #25
n8andm's Avatar
Minneapolis , Minnesota
That is the original lock.
I hope you were able to get the lockset to work, you have the complete assembly now.
Originally Posted by bredlo View Post
Keeping the thread alive... I bought the NOS handle referenced above. It was on the American-flavored eBay, fyi - not sure why it didn't show up in your search, N8.
Took the interior plate off the inside of the door to determine how much of the original setup remains. Exterior handle is gone (with the resulting holes patched) but I'm hoping the "lockset guts" were left alone.
Can't quite tell if it's the same as yours, BradS. If not, I'll certainly be interested in yours if it isn't already spoken for. I can't remove it completely right now to be sure... but I'm feeling semi-confident at the moment since the handle is lining up with the guts. That's shown in a little video clip of the situation:
_______________
/.:N8andM.in.MN:.\
|:Silver Streak Jet:|
n8andm is offline   Reply With Quote
Old 06-16-2011, 01:41 PM   #26
There is a lock and handle on ebay -3 days left and it's at $125 now.
Vintage Bargman Door Handle | eBay
Old 12-10-2015, 12:14 PM   #27
bredlo's Avatar
1954 22' Safari
Hey guys ~ wanted to ask if anyone with the venerable L54 / L55 / H20-2 lockset has ever had one that's stuck. I bought one off eBay last week, and it appears to be seized. I cleaned the rust off in a white vinegar bath and oiled it up.
No dice. Would love opinions on how to fix without breaking it. Video attached:
Old 12-10-2015, 04:10 PM   #28
Mission , Texas
For starters, from the last locksmith I worked in a hospital with ...
"Anyone caught using anything other than LPS-1 on a lock will be shot on sight."
99% of the time, any malfunctioning lock, door, cabinet, padlock outside, vehicle, antique, etc. was miraculously cured with only this lube.
NEVER oil or graphite.
http://www.lpslabs.com/product-details/560
nrgtrakr is offline   Reply With Quote
1956, bargman, doorlock
Need a 35 Amp Bargman 110v Plug!! 1958 745classic Batteries, Univolts, Converters & Inverters 12 09-17-2017 01:38 PM
Just bought a 1977 28ft Argosy- Need Your Expert Advice GarrettRing All Argosy Trailers 18 05-15-2011 05:58 AM
Bargman 5085303 toastie Brakes & Brake Controllers 4 03-10-2011 08:07 PM
'62 globetrotter - bargman L-100 doesn't fit - help? NJtoNC Doors & Locks 4 02-26-2011 03:25 PM
DuraSafe Locks, Any Users ? knunut Off Topic Forum 3 02-08-2011 09:44 AM
