Old 04-14-2007, 07:56 PM   #1
cosmo9404's Avatar
1966 17' Caravel
Tualatin , Oregon
Question Interior Folding Doors for Bathrooms??
We have a 1966 Caravel. PO had separated the rear bathroom with just a thin curtain (yikes! NO privacy!) We're looking to put in some sort of folding accordian door--anyone have any suggestions on where to look? Whatever it is, it would have to be custom b/c the opening is 24 3/4 x 72 3/4.
cosmo9404 is offline   Reply With Quote
Old 04-14-2007, 08:01 PM   #2
RichardT's Avatar
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
RichardT is offline   Reply With Quote
Old 04-14-2007, 08:22 PM   #3
cosmo9404's Avatar
1966 17' Caravel
Tualatin , Oregon
Tried Vintage Trailer supply but the smallest door they have is too big still. Other options we're considering are united shade pleated fabric doors or a custom accordian door.
Old 04-14-2007, 09:07 PM   #4
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I have the same trailer - 66 Caravel. The original acordian door came with it but it was in poor shape. I have posted my solution before so you may find it in my thread history and use the search option above for other solutions.
I got mine at Home Depot - there will be tons of flack to follow for this post. Cheap -YES, Light Weight - YES, buy hey, mine has been in for over a year and looks good, good color match and so far has shown no problems with service lfe. Around $30 at Home Depot. Look in the acordian door section - available online, I had to cut to fie - I left about an inch opening at the bottom. BTW - I used the original slide rail (metal) vice the one that came with the door. I beefed up the punched holes in the plastic with brass gromits that I got in a kit from HD and that should make it lat longer.
PM for more details - Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 04-14-2007, 09:14 PM   #5
RichardT's Avatar
They have a 26" X 72" door.
That is 1 1/4 inches wider then your opening.
It sounds like a perfect fit as you would not want the door to be to tight on closing.
Old 04-14-2007, 10:23 PM   #6
1973 31' Sovereign
Portland , Oregon
Images: 22
I have an accordian door on my home office that I purchased at Lowes for about $30 that may very well be like the one mentioned earlier from Home Depot. The type of construction could easily be cut shorter to what ever length you want. It does come in different widths but the one that I have for a 30" wide opening could easily work for smaller widths without modification.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 04-15-2007, 12:54 AM   #7
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Our '66 Tradewind has a 2 panel folding hollow door that travels a track on top. If yours is a rear bath you probably could find a door and hardware at a salvage yard or if you have basic cabinet skills build one. The panels could then be made fom the same wood in your trailer or stained to match.
Neil and Lynn.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-21-2007, 11:16 AM   #8
cosmo9404's Avatar
1966 17' Caravel
Tualatin , Oregon
Thanks All--We looked at Home Depot and found the accordian doors--will have to cut a few inches off the bottom to make it fit but it may be awhile since my husband had taken it upon himself to replace all the plumbing. If you do cut the door, are there any problems with leaving the hollow part open?
Old 04-22-2007, 01:04 AM   #9
FreshAir's Avatar
1966 24' Tradewind
I would cut a tight insert of wood, pine is ok, and glue them in. If the cut is snug you should not have to use nails. When dry the glue will keep the inserts in place. Doing that will keep the hollow panel strong and spiders homeless.
Neil and Lynn.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 04-23-2007, 12:00 PM   #10
1973 31' Sovereign
Portland , Oregon
Images: 22
An alternative way to fill the cut ends would be to stuff in some wadded up paper or maybe cotton balls and then sqeeze in some caulking material. You can probably smooth it off with a popsicle stick or even trim it some once it has curred. Since it is on the bottom end it does not even have to be a color match.
Malcolm
Old 04-23-2007, 01:01 PM   #11
Marti's Avatar
Images: 20
Thumbs up
Like these... they came from Vintage trailer supply
They were fast with shipping time too... me & husband loves their service...
Marti is offline   Reply With Quote
Old 04-24-2007, 08:13 PM   #12
1963 19' Globetrotter
Moline , Illinois
I got the door for my '63 GT from Camping World, they come from United Shade and are custom sized ,been very pleased with it.
63air is offline   Reply With Quote
compartment doors Dave Cole Exterior Storage Compartments & Access Doors 3 11-01-2016 11:17 AM
Feedback needed for real wood cabinets yukionna Cabinets, Counter Tops & Furnishings 49 05-11-2004 08:45 AM
Cabinet Door Retrofit to Tambour Doors ARGOSY79 Cabinets, Counter Tops & Furnishings 5 08-28-2002 08:34 AM
Roll up doors [tampor] ? niftypkg Cabinets, Counter Tops & Furnishings 5 05-17-2002 07:23 PM
Cabinet roll up doors niftypkg Cabinets, Counter Tops & Furnishings 2 05-10-2002 07:22 PM
