Old 02-19-2014, 01:33 PM   #1
huntingdon , Pennsylvania
interior door trim removal
how do you remove the inner door trim on a 1974 soveriegn?
does it pop off?
i need it off to get the lower inside skin off for a subfloor replacement.
thanks for your help
kokomoscalls is offline   Reply With Quote
Old 02-19-2014, 03:59 PM   #2
1981 31' Excella II
New Market , Alabama
I was able to remove the inner skin around mine once I drilled out all the rivets without removing the door trim. There maybe a hidden rivet or two that can be taken care of with a sharp wood chisel.
Perry
Old 02-19-2014, 04:14 PM   #3
1972 23' Safari
Camas , Washington
slowly, we used a small wonder bar and worked around slowly prying, eventually it came off
Pams72 is offline   Reply With Quote
Old 02-19-2014, 04:15 PM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Assuming that a 74 is the same as a 72, yes the trim pops off. It's a "T" shaped trim where the stem of the T goes into a slot in the door frame. It's held in place with clips, some of which will come out with the trim and some will remain in the slot. To re-install, place the clip on the trim before gently banging it back into the slot in the door frame. If memory serves, I used a small pry bar to remove ours.
Chris
Old 02-19-2014, 05:40 PM   #5
Mixter's Avatar
1976 27' Overlander
My '76 was pop riveted through the door jamb.
Mixter is offline   Reply With Quote
Old 02-22-2014, 02:52 PM   #6
door trim
i can see pop rivets thru the door jamb towrds the inside... i think these are holding the door trim on... i tried to see if it would pop off but it wont so ill drill them out there is maybe 6 or 8 total
Door Hinge Removal possible? Del Gurney Doors & Locks 1 11-14-2011 04:49 PM
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 07:32 AM
Exterior Paint Removal star kitty Clearcoat, Exterior Paint & Trim 4 07-30-2011 01:19 PM
Fresh Water Tank Removal Stork Fresh Water Systems 6 03-04-2011 10:46 PM
