Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 11-17-2009, 07:20 AM   #1
rslaymaker's Avatar
1965 22' Safari
Newbury , Ohio
Images: 30
Installing a Door Knob (Latch or Not to Latch)
I am bogged down again by what seems to be the simplest of things.
I am trying to install a new door knob on my camper. In an attempt to reduce my expenses, I am using a standard door knob, similar to the one shown below.
I not sure if I have the terminology down... But here it goes. It seems that the latch (part that runs the opposite direction of the knobs) is too short for the Airstream door. So, I tried to use the existing camper's latch with the new door knobs... the connection point was not compatible. The rod connecting the two knobs together was larger then the hole in the existing latch. So, I went to work on it... Now, I believe I screwed up the existing latch. So I now have a door knob that does latch. During our trip to Penn Wood, someone told me about extensions. How I understood this, the extension would increase the size of your latch.
Does anyone have any suggestions? Thans in advance for your support.
Robert Slaymaker
rslaymaker is offline   Reply With Quote
Old 11-17-2009, 08:20 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi rslaymaker, I know from working on older houses that you can get an adjustable latch. Exp. Kwikset Latches. If you have a good hardware store take both locks down and see if the have something for you. You might also try a locksmith shop.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-17-2009, 09:52 AM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Locks
Hi! I have PM'd you.
I don't think we discussed this at PennWood. Are you already committed to changing that to a house door lock?
This is something that we would suggest you take the trailer and/or trailer to a good locksmith. Perhaps he can find the extension that you need before you give up on it. The standard house door set has two offset settings of 2 3/8 and 2 3/4. A full service lock shop may have something to change that.
There is a full service locksmith out our way in Elyria that we trust.
Or have you tried a full service RV shop?
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
'72 door latch pacfan Doors & Locks 4 11-11-2010 09:40 AM
67 outside door latch CJ of Okla 1965 - 1969 Overlander 4 04-29-2009 05:58 AM
Door latch for '75 rebel beck Doors & Locks 1 01-07-2006 06:30 PM
door latch grball8388 Doors & Locks 1 04-20-2005 12:51 PM
Door latch Jerry Martinez Doors & Locks 0 08-04-2002 07:08 AM
