Old 06-12-2014, 08:08 AM   #1
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Inner deadbolt throw fell off
We have a 2001 Excella 30'er. Recently I found the inner deadbolt throw on the floor inside. It had fallen off. In looking closely at it I don't see any way for it to be retained on the post ie. allen screw or clip of some kind. The end of the throw knob that would extend into the sheet metal seems to have some sort of bulbous end on it but no way for it to be retained. Am I missing something here that should be obvious ??? There is another throw handle to lock the mechanism so this will only affect the deadbolt.
Appreciate any thoughts or guidance here. ThanX all
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 06-12-2014, 08:42 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
How about a picture?
I have repaired both the dead bolt spring and the tang on the door latch after they failed but a picture will help.
2004 Excursion 4x4
Old 06-12-2014, 02:06 PM   #3
retired USA/USAF
2001 30' Excella
I'll try and get a pix. I don't have the trailer at home so maybe in the next day or 2 I'll get over there.
Roger in NJ
TAC - NJ 18
Old 06-30-2014, 01:52 PM   #4
retired USA/USAF
2001 30' Excella
OK, here goes. A couple of weeks ago I inquired about the inside deadbolt throw falling off. I will attempt to post a few PIX to help out. There is a photo showing the inside of the door to give perspective. Then a close up of the inside of the deadbolt showing where the throw knob would go and then a photo of the displaced throw knob. I just don't see any way for it to be held on. I see two phillips screws to remove the inside cover plate. I have not yet removed it and once I do I may see some sort of retainer that has fallen off. I will attempt to do that but didn't do it today. But, I would think the cover plate needs to be installed before the knob I'm not sure how that would work. We'll see when I take it off. So here goes with the PIX.
ID:	215258   Click image for larger version
Roger in NJ
TAC - NJ 18
Taking inner skins off. Remove AC? Ritagirl General Interior Topics 1 03-04-2012 04:07 PM
Sliding throw rugs noreen&sal General Interior Topics 8 05-29-2011 07:54 AM
Moving throw rugs!!! pappy19 Floor Finishes 11 04-10-2011 08:07 PM
throw this away Zeppelinium Off Topic Forum 20 11-01-2009 09:45 PM
The VAP Throw Down! robandzoe General Interior Topics 33 01-04-2008 11:50 AM
