Old 02-28-2005, 11:19 PM   #1
1976 25' Tradewind
grover beach , California
I'm Locked out!!!
I have a 1976 Airstream land yacht. The key will spin the cylinder but it will not enguage the latch. So I'm locked out. I have tried to take the hindge bolts out, but have run into some trouble getting the bottom bolts loose and with the nuts falling inside the wall. I have purchased a impact wrench and was going to try again, but thought I would check with you-all first. Any suggestions? How can I get into my trailer with out severly damaging anything?
larry smith is offline   Reply With Quote
Old 02-28-2005, 11:26 PM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
Call the lock smith. It will cost you less than the repairs.
Over59 is offline   Reply With Quote
Old 03-01-2005, 06:19 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
The cylinder itself will crack and that causes it to spin in its mount. You could drill it out, it will need to be replaced anyway. If you drill out the cylinder, manually turn the latch and get in, remove the whole lock and you can replace the cylinder. the parts are available, but you will have a new key to go with it.If it matched any other locks then you end up with two similiar but different keys.
Check this thread before you do anything----
http://www.airforums.com/forum...hlight=bargman
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-01-2005, 06:52 AM   #4
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Alternative entry
Can you get in through Storage door?
Maybe get a small kid in through the small door?
And you can always try to remove the rear "emergency exit" window and climb into the trailer.
Smily
smily is offline   Reply With Quote
Help - MH Brakes Locked Up! swebster Mechanics Corner - Engines, Transmission & More... 99 07-31-2017 06:22 PM
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 11:20 PM
Locked out of Campground?!? Stefrobrts On The Road... 5 08-24-2003 01:30 PM
