Old 11-10-2006, 04:15 PM   #1
soldiermedic's Avatar
Florissant , USA
I need a new door knob: prefer a T-Handle!
The current knob on my 68 Safari has seen better days. It hardly ever latches even after I heave all my weight against it. I would rather have the T-Handle design and it be something that locks!
Inland has the original knob, but I am looking for the T-Handle that locks.
Anyone know where to find one?
soldiermedic is offline   Reply With Quote
Old 11-10-2006, 06:14 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
T-Handle?
Hi, Can you post a pic of the T-Handle? I just can't picture what it looks like. Thanks
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-10-2006, 06:25 PM   #3
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
vintagetrailersupply has your choice of inner knob or T-handle.
http://www.vintagetrailersupply.com/...Code=VTS%2D268
Rog
May you camp where wind wont hit you, where snakes wont bite and bears wont git you.
Rog0525 is offline   Reply With Quote
Old 11-10-2006, 06:50 PM   #4
Florissant , USA
Went and took a look. It looks like the one with a knob on both ends is the only one that will work for a late 60's model. I will look for a picture of the handle I desire and perhaps someone will have seen something similar that works.
Old 11-10-2006, 06:59 PM   #5
Florissant , USA
Here is a picture. Something like this for the outside, but to fit my 68 Safari.
Old 11-10-2006, 07:10 PM   #6
1967 22' Safari
1960 Caravel
Images: 8
Make your own.
It looks like you could use the inside of the old lock set and get the T-handles separatley and use this in place of the round handles. Maybe?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 11-11-2006, 01:06 PM   #7
Airstream used a "T" handle lock for the entrance door in 1969 as well as all the compartment doors. They were made by Chessler. The big problem was all to many things got caught by the extended handle that more often than not hurt you or caused damage to the trailer.
The manufacturer of that lock went out of business.
Airstream then decided to use a "flat" lock such as the KT from 1970 to 1977. After 1977, Airstream has used several different locks, but all with a flat exterior surface.
The 1966 to 1969 locks, all had a handle on the inside. In time, as you closed the door from the inside, that handle would easily break. In fact probably 75 percent of that vintage lock was replaced because of the inside handle breaking.
Using a round knob on the inside, solved that problem.
At this point in time, a Bargman L-100 special is used as a direct replacement for the 1966 to 1969 models.
We developed a kit for the 1970 to 1972 models, which replaces the $600.00 KT lock, using the Bargman L-100 special plus some adapter plates. The cost is now less than $160.00. However, it does have a round knob on both the inside and outside, and still keeps your tariler in the Airstream family of parts.
We also developed a lock kit for the 1973 to 1977 trailers that also greatly reduced the costs, and is flat.
Locks for the 1978 to 1991 also became expensive or obsolete, therefore we developed a replacement kit for those years as well, which is flat.
Sometimes a small modification to the door cutout may be necessary when using these kits, but easily justified when you can save hundreds of dollars, or having a entrance door lock that works.
AAA or Good Sam? Which Roadside Assistance do you prefer and why? Jabba Off Topic Forum 19 09-16-2014 09:49 AM
Which chemicals do you prefer? nazz300 Community Polls 13 10-12-2006 03:48 PM
What Kind of Finish do you Prefer? JohnG Community Polls 10 09-11-2004 07:04 PM
Suburban or Van with a 350 or 454...which do you prefer? texasphilter On The Road... 12 04-06-2004 03:05 PM
