Old 06-03-2009, 06:01 AM   #1
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
How to remove this catch?
I posted this question a couple of days ago, but I think my message and pics were some of thse that got lost in cyber space.
How in the world do I remove the brown plastic latch from my screen door? I know that they no longer make this exact latch but that a replacement is available. So how do I get it off!
Thanks, Annette
bullydogsmom is offline   Reply With Quote
Old 06-03-2009, 06:12 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Drive the top off the base with a deftly placed blow.
Use a hammer and a piece of scrap wood. Hit the end edge of the sliding piece to drive it backwards. The spring inside will want to go flying. Then you will find 2 small screws in the base that attaches the latch to the screen door.
Removing is easy. Putting them back together again.... That's the catch.
BTW, If you get it off without breaking it and don't want it I'll take it.
Old 06-03-2009, 06:21 AM   #3
Ottawa , ON
ps, Annette:
I bet your camera has a macro mode switch. It usually has a symbol looks like a little flower. If you engage that when you take close-ups, you'll be amazed at how much more clearly they come out!
Old 06-03-2009, 06:28 AM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Slide your latch to the fully open position - slide a thin stiff putty knife under the rear edge between the slide and body - pry gently up and at an angle. The top is held in the bottom by two "ears". Just being nosy - why would you want to take them off if I can be so bold as to ask.....
Old 06-03-2009, 08:21 AM   #5
1972 25' Tradewind
The tip of the catch is broken off and it would hold the door open.
Annette
Old 06-11-2009, 03:31 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Once you remove them, I would save these parts. These latches are no longer made and are like gold now. Even if the top latch doesn't work in this application it might in another.
Believe me when I say the springs are especially valuable. They have a tendency to fly away.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-11-2009, 08:32 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
When you say the catch tip is broken do you mean the slide latch in the picture you are trying to remove - or do you mean the milky white piece that is on the door frame edge that the above slides over to hold the screen closed. I do realize you may just be showing that one as an example and that there is (was) one on the side of the trailer and a catch on the outer door edge also.
The milky white piece that goes over the frame edge is still available.
Old 06-11-2009, 08:48 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Everyone says that and I believed it too. So I bought up every one that appeared on Ebay a couple years ago. Even Inland RV has said they are not available. Airstream, while I was at the factory said they were not available. Then looking in their lobby store - bingo there they were. You just have to be willing to pay for the extra parts.
http://www.inlandrv.com/catalog/images/18693.JPG
Old 06-14-2009, 09:05 PM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Gary,
Yes, you can still find them and when you do they're expensive, but my understanding is that they're no longer being made.
1958 Overlander
4CU 1st VP
Screen Door Catch. Larry71 Doors & Locks 22 06-13-2010 10:27 PM
whatchamacallit latch/catch- installation? Lumatic Doors & Locks 11 06-27-2007 08:34 AM
Need help with a good replacement cabinet catch Mookie Cabinets, Counter Tops & Furnishings 6 04-03-2006 08:19 AM
Accordian door catch Anon Cabinets, Counter Tops & Furnishings 4 03-12-2005 04:36 AM
Anyone Catch CSI Tonight? Pick Our Community 3 05-17-2003 11:34 PM
