Old 07-06-2014, 01:18 PM   #1
1972 27' Overlander
Loomis , California
How to remove plastic door latch?
The black plastic latch that keeps the door of my new (old?) '72 overlander open has broken. There are several other identical latches, e.g. on the back bumper, that I'm not going to use, and so would like to remove for replacement. The challange is that I cannot figure out how to remove the sliding part (without breaking it) so that I can get at the mounting rivets on the base part.
Anyone know the magic?
Thanks!
digidad is offline   Reply With Quote
Old 07-06-2014, 01:54 PM   #2
1974 Argosy 20
Kooskia , Idaho
Those are diabolical and I never remember how to take them apart. I think, but not sure, that you slide it all the way back and then pry it apart. And it will come apart, eventually.
But, I am sure someone here knows the answer for sure. Yes, it is magic.
Old 07-31-2014, 04:05 PM   #3
1972 27' Overlander
Loomis , California
Finally figured it out. Pull the latch back as far as it will go, and then gently pry up in the middle of the latch. Just a little, on one side, and a then a little on the other. It will then lift right off.
But the tolerance between the grip of the top and the gap on the bottom is really tight, so go gentle. If it doesn't move, it's not aligned.
Old 07-31-2014, 07:20 PM   #4
1974 Argosy 20
Kooskia , Idaho
Glad it finally reveled it's secret.
How to remove plastic wall cover Mark910234 General Interior Topics 2 07-03-2013 12:40 PM
How do I remove door latch on a 1972 Overlander? jazz1945 Doors & Locks 5 10-01-2011 11:19 AM
Plastic bathroom components crack repair with 3M 4240 semi-rigid plastic repair kit Top Upholstery, Blinds, Walls & Interior Finishes 1 05-09-2011 07:11 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
Remove '68 Latch for Rockguard Uberphotos Rock Guards, Segment & Window Protectors 3 05-17-2009 07:33 PM
