Old 12-28-2007, 01:52 PM   #1
azfiredog300's Avatar
Surprise , Arizona
How to open
Hey guys, seems that I am having difficulty getting my access door open to my fridge. At best guess it looks like the PO put the wrong key in the lock and broke it off inside, you can see that he tried very hard to open it with a screwdriver due to it being all bent up. Is there a way I can open this without removing the fridge?
azfiredog300 is offline   Reply With Quote
Old 12-28-2007, 01:54 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Do you have the right key if the wrong one could be removed?
Tom
Old 12-28-2007, 01:59 PM   #3
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Tom-
The problem of trying to open it with a screw driver is that the cam needs to go clock-wise and the retaining ring on the cylinder is counter-clock-wise. A new lock is very cheap ($5.00). I would drill out the center of the lock all the way through and then you will be able to slide the cam to open.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-28-2007, 02:00 PM   #4
Surprise , Arizona
I do have the right key, are the lock setups readily available?
Old 12-28-2007, 02:01 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have a very small drift pin punch try and hammer a flat spot on the end of the key that is jammed in the lock. Don't put a lot of force into this all you want to create is a flat spot that you can then start a small drill bit, .050, into the key. If yu can drill in about 3/16 then insert the smallest easyout you can find into the key and try to pull it out.
Another way if you can get to the first pin cut on the key with a small pick set you may be able to pull the key out with a pick. Take a straight pick heat the tip and bend a small 90 degree point on the pick. then try to reach in on the top of the key and pull out.
2004 Excursion 4x4
Old 12-28-2007, 02:02 PM   #6
Surprise , Arizona
What size drill bit should I use if I drill it out?
Old 12-28-2007, 02:06 PM   #7
HowieE's Avatar
Images: 12
To drill the lock set out. Start with an 1/8 in. and work up. If you start big it may snag on you.
2004 Excursion 4x4
Old 12-28-2007, 02:07 PM   #8
TomW's Avatar
1967 26' Overlander
I would SuperGlue a small piece of metal to the broken key, and try to remove it.
New locksets are readily available at many places.
Getting one that could be keyed to the rest of your locks might require a trip to a competent locksmith's shop.
Tom
Old 12-28-2007, 02:17 PM   #9
Surprise , Arizona
Ahhh, the amazing superglue. Almost as important as duct tape in the world of today. I will try the superglue first then work my way through the drilling process. Start easy then work out from there. Thats why I love this forum, it brings great ideas to light. Thanks
Jerry.
______________________________________
The only true failure is the failure to try!!
The open door dump... PaulO General Interior Topics 15 03-26-2008 07:12 PM
Can't open the windows ! IrishRover2 Windows & Screens 13 02-08-2007 04:14 PM
Why can't I open this thread? CMF Forum Admin, News and Member Account Info 3 08-24-2005 09:53 PM
pullrod stuck open Trailerbunny LP Gas, Piping, Tanks & Regulators 5 12-15-2004 05:18 PM
