Old 10-14-2014, 10:33 PM   #1
Anchorage , Alaska
How to dis-assemble the door knob
I guess I have a few questions. Probably should post each in a separate thread, but here goes.
Can anybody confirm if this is the original door knob for a 1963 Bambi ?
I can completely dis assemble the interior knob, but I am stuck and cannot get the exterior knob off completely.
Apparently there is no longer an electroplating outfit in Anchorage. Any suggestions where I could send this to get it re-chromed?
ID:	224402   Click image for larger version
ID:	224404   Click image for larger version
Aktundra is offline   Reply With Quote
Old 10-15-2014, 07:10 AM   #2
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I cant answer either of your questions, but I want to see the answers, so I am giving your thread a bump.
Old 10-15-2014, 07:55 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Not worth it
If you went the electroplate route you would be in way over your value. Time and money count. Go to Ebay and buy a new replacement way less than the route your on. Both in time and money.
Old 10-15-2014, 08:06 AM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
I believe that it is a Bargman L 200 or so.... No longer in production, but found on other old trailer manufacturers as well. Hunt for one on all brands of old parts trailers you can find. You might get lucky. There are new old stock and reproductions available. Today, there are a half dozen for sale on eBay, which is a good place to find a replacement if yours doesn't function well. There is also a rebuild kit available.
If yours is working well, but has pits and peeling chrome, I'd lightly flap sand the surface smooth and rub in some chrome paint to into the pits to retard further surface deterioration, clean, lubricate, and reinstall it. Put it on your list of parts to lurk for, and maybe you'll find a nice original one for less than $400. By weight and size, it might be the most expensive replacement part on your entire trailer.
ALUMINUMINUM is offline   Reply With Quote
Old 10-15-2014, 08:12 AM   #5
65will
65will's Avatar
1969 25' Tradewind
Greenwich , New York
to remove handle
Hello, I don't know if this handle is correct for your 63, I have that handle on my 69 Trade Wind. To remove the handle you need to pull the pin that shows in your picture. I removed mine with a pair of dikes ( side cutters). As for the plateing, there is a place in Philly.They are on the internet. you send them the parts, then they give you an estamite, at that point you tell them yes or no, if no they send your parts back to you. That lock is not made any longer. They do turn up on e-bay now and then, but sell for around $400. I buy spares for parts when I find them cheap enough. good luck.
65will is offline   Reply With Quote
Old 10-15-2014, 08:33 AM   #6
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
Aktundra
I can confirm that removing that perpendicular pin will allow you to slide the handle out of the outside plate. Take a pair of needle nose pliers to pull out.
I don't think for the looks of your priceless Bambi that you would want to spend a lot of money on re-chroming that lock. If you want a new one, send me a private message. I have lots of these locks new in the box and the Rebuild kits if you want to rebuild it.
Of course someones suggestion of sanding and using chrome paint is a much cheaper way to go as long as the lock functions. If you need help putting it back together I will help you with that. Attached is a pdf of the exploded view of the lock if you need that.
I hope that helps you.
Rick
montanablue is offline   Reply With Quote
Old 10-15-2014, 08:44 AM   #7
1997 25' Safari
1973 25' Tradewind
Pdf didn't post. Let's try these.
Rick
Name:	Bargman L-100 Exploded View 3.JPG
Old 10-15-2014, 04:09 PM   #8
1963 19' Globetrotter
Folly Beach , South Carolina
It looks just like the one on my '63 Globe Trotter
Crowman is offline   Reply With Quote
KT Lock dis/ re- assembly Lumatic Doors & Locks 5 05-30-2014 03:25 PM
Simple question about low voltage dis panel schematic? Mrcrowley Batteries, Univolts, Converters & Inverters 10 08-18-2008 07:25 PM
Dis Jus' ain't right! 85MH325 Our Community 29 03-16-2004 07:17 AM
