Old 06-25-2012, 12:24 PM   #1
Plainfield , New Hampshire
How to determine which lock I have?
My head is swimming looking at all of the photos of Bargman locks. I haven't seen mine yet. I saw a diagram that said "Airstream Door Lock 70-77" which looks sort of like it, but does not say Bargman or any other brand. I have a 73 Overlander 27ft rear bath, serial #127D4 J1501. I am missing the tiny screw (on that diagram part 83212?) that holds the inside handle in place (screwing down from above) and the slider that locks the door from the inside for example at night. Any way to look this up to be sure?
MikeAir is offline   Reply With Quote
Old 06-25-2012, 12:49 PM   #2
1981 31' Excella II
New Market , Alabama
It is probably a common screw. You have a pic of a similar screw?
Perry
Old 06-25-2012, 01:24 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You most likely have the expensive to replace KT lock. Parts are still available
Old 06-25-2012, 02:27 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Just an FYI - if the VIN you have showing above is correct - you have a 74 Overlander - not a 73. The first digit is actually an I not a 1...
Old 06-25-2012, 05:41 PM   #5
mapleton , Utah
Has anybody ever done a photo series of the common lock types? It might be very helpful to identify what we all have. Just a thought Everytime I get one my wife says "let it go"
tim
rumrunner is offline   Reply With Quote
Old 06-25-2012, 06:35 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I believe the set screw in the door handle is 1/4 x 20. The screw for locking the door is a 6 x 32. Take the handle to any well stocked hardware store, look for set screws. For the lock handle. I used a 6 x 32 x 1 1/2" machine screw, then slipped a small piece of rubber tubing (vacuum line hose) over the screw. Leaving about 1/4" of threads exposed. Installed the screw until it was held tight by the compressed tubing.
This lock mechanism has the tendency to lock itself, especially if you slam the door. I close the door by holding the handle out, then release it to engage the bolt. The locking mechanism has roll pins and they are very brittle. They will shear off if the mechanism is subjected to the shock of slamming the door.
I would highly recommend installing a dead bolt. Then tighten the interior door lock handle (screw) enough to prevent the bolt from sliding down on it's own.
I installed a new lock cylinder and it was still a challenge to get the door locked and unlocked from the outside. Now that I have a dead bolt there is no need to use the lock cylinder.
TG Twinkie is online now   Reply With Quote
Old 06-26-2012, 10:40 AM   #7
The exploded drawing that looks very much like my lock is at http://cdn.airforums.com/forums/atta...5&d=1339006095 The lost item is 83212. It seems like a tiny set screw. Thanks for your ideas.
Old 06-26-2012, 10:45 AM   #8
Respond to Gary re 73 vs 74 and 1 vs I This prompted my new thread under VIN questions. Thanks.
Old 06-27-2012, 06:46 PM   #9
1981 31' Excella II
Just take the handle to a local bolt supply store and they will fix you up.
Perry
Old 08-19-2012, 06:58 PM   #10
1964 26' Overlander
Toronto , Ontario
Rumrunner... I totally agree. Would love to have some sort of reference. Still trying to figure out which lock I have on my 64 Overlander!
wigwag is offline   Reply With Quote
