Old 05-15-2008, 06:09 PM   #1
1972 31' Sovereign
Linton , North Dakota
Question How do you separate this?
I'm not certain if this is the appropriate place to post this but here goes.
I need some help, the latch that holds the screen door to the door has a broken spring. I have opened the liner on the door but this latch is screwed on from the outside. Can someone tell me how to pop this latch apart so that a new spring can be inserted.
Tom
north dakota is offline   Reply With Quote
Old 05-15-2008, 06:30 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
I'm betting
Your latch assembly probably pops off of a baseplate.
The way I see it, it would have been too much trouble at the factory to secure the assembly before the door was put in place.
I think that you can pop the latch free from a baseplate, replace the sping (or top assembly), and pop it back into place.
Tom
Old 05-15-2008, 06:44 PM   #3
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Neither my 67 or 83 even has a spring on the one on the inside. They just slide. (Now the spring on the outside door retainer on the 83 has a broken spring, but that's another story)
Vaughan
Old 05-15-2008, 06:45 PM   #4
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Is that latch original? What years used this exact latch?
Is it still available?
Seems like I read a thread about opening these latches and replacing springs not long ago. They may have been talking of another type latch tho.
I will try to find it. If successful I will of course post link here this thread.
EDIT :
try this thread
http://www.airforums.com/forums/f453...ion-32649.html
Distantdrummer is offline   Reply With Quote
Old 05-15-2008, 06:48 PM   #5
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
My 76 has a spring that allows it to automatically snap back and hold the screen. Don't ask me how you get it apart because I haven't tried. I do know that the outside door hold has no spring left, but I don't think it makes much difference. I have a replacement but not worth the trouble to pop the rivets and replace.
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Old 05-15-2008, 06:54 PM   #6
Originally Posted by north dakota
Attachment 60481Hi all,
Tom
That black latch was used for years to hold the screen door to the entrance door and to hold the lid closed that was attached to the bumper, called the sewer hose compartment.
That part was discontinued several years ago.
The latch was attached to the door with a couple of pop rivets. Then the sliding cover was snapped in place.
Unfortunately if you try to pry the sliding cover off, you will warp it, rendering it useless.
Basically, it was a one time deal.
It can be replaced using the later main door holdback and the metal housing that covered it.
You may or may not need to add a shim to make it work in your case, to hold the screen door to the entrance door.
We have sold hundreds of those parts, for that purpose.
Old 05-15-2008, 06:55 PM   #7
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That latch can be carefully pried off its base, which is how we fixed ours. I left the base screwed to the door, carefully pried off the latch, installed a new spring, and snapped the latch back in place.
Old 05-15-2008, 07:25 PM   #8
1972 31' Sovereign
Thank you all for the quick responses. I'll try the pry method if that doesn't work I'll be calling Andy.
Thanks again for all the inputs. I'll post the results.
Tom
Old 05-15-2008, 08:22 PM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Slide the latch back to the most open position and then pry it out with a thin blade from the rear and side. It has "ears" on it underneath and is flexible enough to remove and go back in.
To get the original part buy this latch from Inland or any Airstream dealer and part it out.
Old 05-15-2008, 08:23 PM   #10
Well Preserved
1993 21' Sovereign
Sounds like I got lucky with the one I did...
Old 05-15-2008, 09:14 PM   #11
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Andy seems all the small parts I need this week are discontinued , I need one of those latches for the bumper cover and was going to call you tomorrow! Is 18693 a good replacement for that purpose also? Will a shim be needed, and is it close enough that it will match the other side or should I replace in sets?
goransons is offline   Reply With Quote
Old 05-15-2008, 09:27 PM   #12
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Would be a good investment of time to use a hair drier to warm the door latch to let it pop free easier, I've had mine apart in 90~F weather in sunshine and didn't have much grief about it...
Old 05-15-2008, 09:28 PM   #13
cameront120's Avatar
1972 25' Tradewind
This is exactly how I fixed mine as well. The key is to slide it back to the open position, as Gary said.
North Vancouver, BC
Old 05-15-2008, 09:42 PM   #14
1972 31' Sovereign
Once again, thanks for the added info I'll give it a try in the A.M.
Tom
Is there a new separate oven bdogz Stoves, Ovens & Microwaves 5 08-29-2005 08:07 PM
