Old 08-01-2010, 04:01 PM   #1
1972 27' Overlander
Newark , Ohio
How do I remove door latch on a 1972 Overlander?
Does anyone know how to remove the entry door latch assembly on a 1972 Overlander? I removed the three screws from the inside. But still can't remove latch assembly. The door handle was broken by the thieves that stole my AS. Got it back, but with damage and parts missing.
jazz1945 is offline   Reply With Quote
Old 08-01-2010, 04:09 PM   #2
azflycaster's Avatar
1975 25' Tradewind
Dewey , Arizona
Images: 62
You have to remove the inside handle and locking thumb screw. You have the three inside screws out. There is one more on the side that you can only get to with the door open. I read that you need to pull back the inside skin on the door, but I was able to remove mine without doing that. The lock will be sealed to the door and may be a little tough to get off.
Richard
Old 08-01-2010, 05:38 PM   #3
1972 27' Overlander
Newark , Ohio
Thanks, Richard, I had removed all four screws, but was afraid to push too hard to avoid damage.
Jack
Old 09-30-2011, 04:27 PM   #4
1972 31' Sovereign
Beaumont , Texas
Door latch 1972 Overlander
I also have a 1972 27' Overlander. The exterior door latch is broken. Were you able to find any replacement parts? I have not removed mine yet. I have only recently purchased the unit and am up to my hips in cleaning and checking out everything. Please advise me if you have a source of parts. I haven't done my research yet.
Howard "Buck" Newmans
howardnewmans@att.net
Cell: 409-679-9449
Beaumont, tx
HNewmans is offline   Reply With Quote
Old 09-30-2011, 04:58 PM   #5
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Check Out of Doors Mart or Inland RV. They both have rebuild kits. Will be doing my own soon.
Flynavy is offline   Reply With Quote
Old 10-01-2011, 12:19 PM   #6
1972 27' Overlander
Newark , Ohio
Howard,
I was able to repair it myself. The shaft had broken at the point where a drift pin went thru it. I removed the cam on the shaft and replaced the shaft and re-welded it.
Jack
'72 door latch pacfan Doors & Locks 4 11-11-2010 10:40 AM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 10:52 AM
Remove '68 Latch for Rockguard Uberphotos Rock Guards, Segment & Window Protectors 3 05-17-2009 08:33 PM
67 outside door latch CJ of Okla 1967 Overlander 4 04-29-2009 06:58 AM
closet latch on 65 Overlander 65 overlander Cabinets, Counter Tops & Furnishings 2 02-07-2007 01:18 PM
