Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-02-2005, 04:13 PM   #1
59er's Avatar
Profile:  1959 18' "Footer"
1964 26' Overlander
birmingham , Alabama
Images: 8
hinges for a 63 entry door?
Does anyone know where I can find a replacement pair of hinges for a 63 tradewind?
Doug
59er is offline   Reply With Quote
Old 05-02-2005, 04:14 PM   #2
59er's Avatar
1964 26' Overlander
Images: 8
here's a pic of the damaged hinge...
Name:	63 AS hinge 2.jpg
ID:	11921   Click image for larger version
Name:	63 AS hinge small.jpg
Doug
Old 05-02-2005, 04:15 PM   #3
Commercial Vendor
Profile:  Corona , California
Doug.
Those hinges are no longer available.
You might find some, from a wrecked unit.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 05-02-2005, 06:00 PM   #4
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Right down the road from you is Camper Repair Center in Montevallo. They repair Airstream wrecks all the time and might have some laying around. 205-665-2531.
Randy
www.bestconverter.com
rvtirepressure.com
Old 05-02-2005, 09:31 PM   #5
59er's Avatar
1964 26' Overlander
Images: 8
Camper Repair Center has no idea what they have and what they don't have.....
I have stopped in there and talked with Sonny. He's very helpful. I also met his dad. that's all I'm going to say.
I guess I should have worded my question more specifically. Anyone know of a possible source for a salvaged pair. I assumed it would have to be taken from a donor but wasn't very clear in my post. sorry.
Doug
Old 05-02-2005, 10:01 PM   #6
fireflyinva's Avatar
Profile:  1961 22' Safari
Vienna , Virginia
Have you considered getting it repaired, possibly have the broken pieces fabricated? If you have a good metal shop in town, they may be able to make it work again and save you from having to hunt down the right parts. I don't know if these are particular to the 63s--it certainly does look different from the hinges on our '61 (though I suspect they may be replacements, too).
Mary
Mary Dotson, WBCCI/WDCU #9026
Our Airstream reconstruction adventure continues! Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 05-02-2005, 10:25 PM   #7
Commercial Vendor
Images: 21
Doug,
I was just trying to help. Good luck.
Randy
rvtirepressure.com
Old 05-03-2005, 08:37 AM   #8
59er's Avatar
1964 26' Overlander
Images: 8
Sorry Randy,
I'll get down off of the soapbox now...
BTW, this IS one of the nicest, most polite forum boards that I've been a part of...
I didn't intend to drag it down because of an unfavorable experience.
I do appreciate any advice given.
thanks as always.
Doug
Entry Door Lock Set Hunt ends at Inland Grady White 1963 Ambassador 3 12-16-2004 10:08 PM
Exterior Door Hinges LKappenman Doors & Locks 24 01-23-2003 09:49 PM
Door Swing History hex Our Community 1 11-10-2002 04:39 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 12:11 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
