Old 08-27-2010, 08:25 AM   #1
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
Hinge replacement
I need to replace the hinges on my 1973 Argosy 20'. I have searched and found that apparently you need to remove the inner door trim. My trim is a 1" solid piece that I don't see how to remove. Can anyone give me direction as to how to replace my hinges.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is offline   Reply With Quote
Old 07-17-2011, 10:14 AM   #2
1977 20' Argosy 20
McCall , Idaho
Removing door hinge
I'm in the same predicament. I plan on removing the interior skin to access hinge nuts. I've replaced original refrigerator and will start new enclosure trim panel flush with door trim so any cutting or drilling of interior skin won't be visible. Hope to complete this work in the next six weeks.
babaloo is offline   Reply With Quote
Old 07-17-2011, 10:33 AM   #3
1988 25' Excella
Trumbull , Connecticut
Hello fellow door people. I have an 1988 Excella and the hinge bolts were all rusty so thinking that the engineers at Airstream were smart and would put captive nuts on the inside (ha ha) I proceeded to remove them. The first one went great but the second one just started to spin. I thing you know the rest of the story. My inside trim is also one piece of extruded aluminum. To remove mine there are rivets on the edge that is covered when the door is closed and also rivets on the inside part that overlaps the inside skin. I had to vemove all the rivets around the entire door trim. When these rivets were removed the trim will be able to be removed. After the trim was removed I could pry the inside skin far enough away to get a tool in there to hold the nut so I could tighten up the bolt. So it sits with one nice and shinny bolt and three rust ones but all of them tight. Hope this helps.
Happy camping. nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 07-17-2011, 10:44 AM   #4
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
The interior door trim will just pry out. It is actually a T shape and is held in with clips.
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-20-2010 11:39 AM
need J hinge arodriguez60 Windows & Screens 2 12-09-2008 09:25 AM
battery compartment hinge replacement flash Classic Motorhomes 2 04-25-2007 06:03 PM
Door hinge replacement BB 55 Bubble Doors & Locks 4 08-15-2006 04:17 PM
Window hinge replacement kstring Windows & Screens 1 02-13-2006 08:00 PM
