Old 11-08-2013, 07:33 AM   #1
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Hinge Pin works out
Hi All,
We are having trouble with the top hinge pin on the front door coming out when we tow the AS. We've had it fixed by the AS dealer, but still it keeps inching out and has to be pounded back in every time we tow. Any suggestions on how to keep it in place?
kswelsh is offline   Reply With Quote
Old 11-08-2013, 07:36 AM   #2
Originally Posted by kswelsh View Post
Hi All,
Drill a small hole through the hinge and the pin.
Then install a small "split pin" into that hole.
Old 11-08-2013, 07:38 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
In the later models the hinge pins come with a grove and keeper ring. Get the newer style hinge pin from Airstream to replace the original and your problem is gone.
Doug and Cheryl
Old 11-08-2013, 07:46 AM   #4
dznf0g's Avatar
Oswego , Illinois
The grooved pin, with e-clip is available through your AS dealer. About $20, IIRC. I got two, but have only installed the bottom one since that was the only one working it's way out. Top one is still tight. The grooved pin cures the issue and using locally procured 1/4" e-clips stacked in the hinge half gaps allows for precise door height adjustment. Keep well lubed with your favorite "dry lube".
-Rich-
Old 11-08-2013, 08:05 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Red Loctite and stake the pin has worked for six Seasons.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-08-2013, 08:08 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
The previous owner of our AS had staked the pins like that also, no idea of course if he also used loctite. -
In any event we have now had the trailer for 5 years and the pins have not budged.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-08-2013, 08:09 AM   #7
dznf0g's Avatar
Oswego , Illinois
Robert,
Staking and loctite worked for the top hinge, but the bottom hinge pin serrations had "wollered" the hinge hole too extensively for staking and loctite to work.
IMO, I would immediately change out the lifted pin with the new grooved pin. The re-staking, in my case, made the hinge look pretty "punched up" over several repair attempts.
-Rich-
Old 11-08-2013, 10:55 AM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I covered this in a seminar last Alumapalooza. Using a #30 drill bit, drill into the top of the hinge into the hinge pin, roughly halfway through, from the front. Then tap a 1/8" roll pin into the hole. That will keep the pin from walking up out of the hinge. Cost? $.35
Old 11-08-2013, 11:06 AM   #9
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Anybody got a picture of the roll pin repair technique?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 11-08-2013, 12:48 PM   #10
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Tapped the pin back down,then I took a punch and tapped the outside edge surrounding the pin in three places to lock it down.Never moved again.
Old 11-08-2013, 07:50 PM   #11
kswelsh's Avatar
2012 30' Classic
Wildwood , Missouri
Thank you all for your great options. I really appreciate all your help.
Old 11-08-2013, 08:32 PM   #12
Well Preserved
1993 21' Sovereign
I also did this at Alumalina. Next time I drill and pin one, I'll try to remember to snap a picture.
Old 11-10-2013, 08:03 PM   #13
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
That's great advice, Terry!
Skatiero is offline   Reply With Quote
