Old 07-06-2007, 01:18 PM   #1
HowieE's Avatar
Princeton , New Jersey
Images: 12
Hinge pin removal question
How do I remove the hinge pins on my 91? There is no hole at the bottom to drive the pin up and out.
The reason for removal is to shim the hinge back to the original height.
2004 Excursion 4x4
Old 07-06-2007, 02:10 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Good question and one I'd have raised soon. I'm taking the door off my Argosy today and the screen door will be in the way unless...
5 meter Langford Nahanni
Old 07-06-2007, 04:57 PM   #3
Drill a small hole at the bottom of the pin.
Then using a small punch, drive the pin upwards.
Dent Removal uwe Ribs, Skins & Rivets 11 01-17-2016 02:48 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 04:36 PM
Door hinge bjstewart1 Doors & Locks 0 10-09-2002 07:22 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 11:26 AM
Wardrobe Removal ??? 54FlyingCloud General Interior Topics 1 07-25-2002 03:22 PM
