Old 08-08-2004, 02:53 PM   #1
Lightbulb Hinge on Door Squeaks
HELP!
My doors hinge Squeaks. It's so loud!!!!!!!!!!!!!!!
I have tried WD40 but that doesn't help at all.
So, please enlighten me on what I should be doing to correct this aweful noise that wakes the dead.
71excella500 is offline   Reply With Quote
Old 08-10-2004, 09:55 PM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
If WD-40 isn't doing the job, you need a heavier oil/grease.
You might want to remove the hinge pins one at a time and slather on some axle grease.
If the door isn't aligning properly, that's a different story.
Rog
May you camp where wind wonít hit you, where snakes wonít bite and bears wonít git you.
Rog0525 is offline   Reply With Quote
Old 08-10-2004, 11:08 PM   #3
JohnG's Avatar
Sometimes you have to just keep on sprayon the WD 40 on. I guess if it is in a tight area it may take it a bit to get into the sqeaky zone. I neve had anything that WD 40 wouldn't get, but sometimes it can take a little while.
Just adding my 2Ę worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-11-2004, 09:20 AM   #4
71Excella500
WD-40 is a temporary fix.
Lube the hinge everyday, along with opening and closing the door, using "silicone spray."
Eventually, the noise will disappear.
All the exterior hinges should be lubed at least twice a year.
Entry door hinge TomW Doors & Locks 35 07-17-2008 07:04 AM
Door Hinge Adjustment Cracker Doors & Locks 11 11-02-2003 07:24 AM
Door hinge bjstewart1 Doors & Locks 0 10-09-2002 06:22 PM
