Old 06-18-2015, 04:16 PM   #1
1995 34' Limited
nashville , Tennessee
hinge on door coming lose
I have a 1996 limited airstream---- the upper hinge has become lose and the door drops when it is open. the big screws just keep turning like they are in a nut or something. with the interior wall the way it is, you cannot get to the backside where it screws into---- does anyone know the best way to repair this? thanks
hemilust is offline   Reply With Quote
Old 06-18-2015, 07:14 PM   #2
1998 30' Excella 1000
Livingston , Texas
Search the forum. There several posts addressing this issue. Including a few by myself... but no time to find them just now. Good luck.
Siegmann is offline   Reply With Quote
Old 06-26-2016, 04:25 AM   #3
art
have the same problem .Im searching too
art is offline   Reply With Quote
Old 06-26-2016, 08:12 AM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Unfortunately this is another problem A$ has had for years since they use a nut on the back side instead of a threaded plate that matches the hole pattern of the hinge.
So now you get to drill holes in the inner skin to gain access to the nuts with a wrench.
Old 06-26-2016, 11:14 PM   #5
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Remove the inner skin. It is just pop-riveted. Then you can wrench the nut side. I would use a bit of thread locking glue to keep it the way you put it.
When you put the skin back on just make sure the door shape does not change, the inner and outer skin does effect the curve in the door.
sgschwend is offline   Reply With Quote
Old 06-26-2016, 11:19 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Airstreams built from about 2011 I believe, have the plate on the inside. One of our hinge screws loosened and we were quite able to snug it down very tight from the outside.
I believe you can get this plate from Airstream and put it in your unit if you decide to pull the skin back.
Doug and Cheryl
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 01:06 AM
How many AS did you lose? wannaroam Our Community 21 10-31-2006 11:23 AM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 11:00 AM
Lose the awnings? lessen Awnings 46 06-12-2006 04:24 PM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 08:06 AM
