Old 06-21-2014, 02:28 PM   #1
1972 31' Sovereign
Lake Elsinore , California
Hinge is sloppy
1972 International Sovereign 31'
My door hinge has what seems to be excessive slop. The door also seems to be sprung which may be making it seem worse, but the hinge may need repair.
So my question is, are there repair kits like bushing or new pins to tighten them back up?
It is so sloppy that it looks like someone took some wire and made like an upholstery hog rig to take up some of the slop.
MacDad is offline   Reply With Quote
Old 06-21-2014, 02:49 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I reamed and bushed mine. It is shown in my thread below
Old 06-22-2014, 11:49 AM   #3
1972 31' Sovereign
I posted there to help me find where I left off reading...wow good stuff.
So just as a follow up question, you only bushed the door part of the hinge, replaced the pin with just a random piece of SS rod cut to length and drilled for a new roll pin?
Old 06-22-2014, 05:11 PM   #4
Aerowood's Avatar
Arvada , Colorado
Yes
Old 06-22-2014, 06:20 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My hinge pin is worn and sloppy also. Aerowood did a great repair on his Globetrotter and I have taken notes!
Here is a bit more information on the single hinge doors from Vintage Resources.
Removing a Single Hinge Door - Vintage Airstream
I thought it might be helpful to you.
David
Old 06-22-2014, 08:34 PM   #6
1972 31' Sovereign
Thanks for that link David.
Someone already tried to use a hacksaw or something to cut a slot in the top and there is some tool marks like they tried turning it with a screw driver...or is that factory to rotate the pin to align the roll pin?
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-20-2010 11:39 AM
Sloppy step slots? blickcd Steps 2 05-29-2009 11:23 AM
Sloppy Steering... Auretrvr Classic Motorhomes 46 11-12-2006 01:23 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 03:36 PM
Hinge pin movement jcanavera Doors & Locks 15 10-04-2002 10:26 AM
