Old 11-02-2013, 12:17 PM   #1
1990 33' Land Yacht
Anytown , USA
Cool Help with Keyless Entry - hidden program button location for 1990 33' Land Yacht
Hello folks! I'm new here
My 1990 Airmstream 33' Land Yacht came with a keyless entry system equipping the deadbolt - we weren't given any instructions or the current code or a deadbolt key, and our manual just says
"The 'hidden program button' is located in your galley cabinet toward the main door"
which cabinet would that be? it's a rather vague description and though we've searched high and low we can't find it. Any ideas?
Thanks a million!
Bertha is offline   Reply With Quote
Old 11-02-2013, 03:35 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I don't have the keyless entry but do have a switch on the dash that can lock the deadbolt. AS has the wiring in place but it was an optional extra if they added the remote and electronic sending unit. I found the wiring and part of the system under the dash near the brake pedal, left of the steering column.
Old 11-02-2013, 04:06 PM   #3
The code is usually on the box that the harness plugs into, should be 5 digits
0557 is offline   Reply With Quote
Old 11-02-2013, 04:35 PM   #4
1990 33' Land Yacht
Anytown , USA
Yeah we've figured out how to lock it that way, but it doesn't really help with the key.
Old 11-02-2013, 04:36 PM   #5
1990 33' Land Yacht
Anytown , USA
the box that what harness plugs into? I'm sorry I'll need you to explain it to someone who understands none of this
Old 11-09-2013, 11:42 AM   #6
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Sorry to take so long to get back to your problem but it is the weather to go camping and we did.
I will add to what I had said before since you didn't think it applied to you.
1. I have electric door locks
2. Airstream uses the circuit that powers them to add in a remote control.
3. the control module is under the dash like I said.
4. you have to find the black box, into it will be plugged a remote controller this is what your remote talks to.
I am posting pictures of the black box, it's circuit board and wiring diagram.
Post if you find it.
ID:	199625   Click image for larger version
ID:	199627   Click image for larger version
