Old 12-23-2015, 11:12 AM   #15
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
If you are not level, AS are so tight it will put the door in a bind when closed..
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 12-23-2015, 11:36 AM   #16
1962 22' Flying Cloud
Raymond , Ohio
I got locked inside our "Tin Tipi" this past summer my husband was outside and in a panic as I had just had heart surgery.
I took the inside plate off and removed the handle ,Red then took off the outside knob and used needle nose pliers to open the lock.
Jan Tillman is offline   Reply With Quote
Old 12-23-2015, 12:55 PM   #17
Center Moriches , New York
Sorry but, your trailer is hosed..........
I'll take it off your hands for $50.......
NY24 is offline   Reply With Quote
Old 12-23-2015, 01:31 PM   #18
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I got locked out over the summer but for a different reason. Our trailer has a deadbolt lock that is thrown from the inside only. On a rough road it vibrated closed on us leaving us locked out. Had to climb in through the rear and up under the bed. Same thing happened to a friend a few weeks later while on an Airstream caravan but they couldn't get in as easy as I did. They had to remove the door.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-23-2015, 02:46 PM   #19
lindaebrewer's Avatar
2015 23' FB Flying Cloud
Sacramento , California
We had the opposite problem. The mechanism that locks the door slid down when we closed the door from the outside. Keys were inside. Only open window was into the bathroom. Husband cut the screen & crawled through. (5'11", 150 lbs, triathlete) Now keep an extra set of keys in the TV.
lindaebrewer is offline   Reply With Quote
Old 12-23-2015, 02:56 PM   #20
Long Island , New York
Originally Posted by JBBeaubeaux View Post
[snip]
Any advice would be greatly appreciated!
Wondering if you have any feedback on what might have caused your problem, including the various suggestions made here and the possibility that the lock internals might have frozen overnight temporarily . . .
Thanks.
Old 12-23-2015, 03:35 PM   #21
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
Thank you for everyone's advice
I really appreciate everyone's advice and help.
Here is what I discovered.
Upon closer look I discovered one of the screws holding the inside plate to the door handle was loose. See attached photo of which screw it was.
After getting the door open, I removed all 3 screws and pulled the plate away from the door.
I was then able to reposition the inside handle to the 3:00 o'clock position and reinstall the 3 screws.
So.... I am guessing that the loose screw allowed enough 'play' inside the door mechanism for the handle to 'slip' and disengage, thereby stranding us inside.
NOTE TO SELF: Keep a phillips head screw driver handy inside the AS and always check to make sure the 3 screws are tight.
For those who want to see a 61 year old man crawl out of the fire exit, attached is a photo.
Again, thanks for all the advice!!!!!!!
ID:	254493   Click image for larger version
2001 Excella 30' (Beauty)
2014 Ram 2500 Diesel 4x4 (The Beast)
http://www.LivingInBeauty.net
JBBeaubeaux is offline   Reply With Quote
Old 12-23-2015, 03:45 PM   #22
Thanks for the feedback. Glad to know the cause.
Rather a more graceful exit than I had pictured!
Old 12-23-2015, 04:21 PM   #23
2007 22' International CCD
His window is much bigger than mine..glad to se he's in good shape. Ours takes climb on rear desk, slide legs through from sitting position, then roll over and try to find the bumper as a step to get out. Undignified no matter how you try to do it. We keep tools inside and extra keys securely outside just in case.
KE4GNK/AE
Old 12-23-2015, 04:22 PM   #24
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
This is a chronic issue for us. The door has popped open in the middle of the night all on its own. When we were camping at NTAC last April the inside handle started just spinning around loose and wasn't engaging with the mechanism inside at all. As I was getting a screwdriver to take off the inside plate and handle it started working on its own. The trailer was broken into while in storage and the original handle was damaged beyond repair. A locksmith replaced it with a round handle (which I really just don't like, I want my airfoil shape handle back), they got it locked and there it sat in storage for many more years without being used so no one knew the door handle was not working. I agree with the stabilizer idea because I know for a fact the stabilizer do torque the frame the doors don't work the same when it is over-stabilized. And I have had the door frozen shut by moisture on the outside. But it very well could be that a prior owner replaced that handle and it was not correctly installed. My big concern of course is being able to get out in an emergency so I have this at the top of my list for repair before next season
kdickinson is offline   Reply With Quote
Old 12-23-2015, 04:30 PM   #25
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That's it. That photo is the one I wanted to see. Very funny-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-23-2015, 10:01 PM   #26
2004 22' Safari
Albuquerque , New Mexico
Been there, Done that...
When you level the trailer, check to see the bottom of the door is level. It makes a difference. If your mechanism pulled out, you need the Overlander solution as well, but if you get stuck inside and have that plate on, you can't get through the screen door to do anything.
I had this happen one night at a star party and used the patio light (accidentally) to draw attention to my trailer. Livid astronomers formed a lynch party and showed up at my door... and when I explained I was locked in, they let me out and calmed down some.
I got out and removed the handle and plate, and could trip my mechanism from inside with a screwdriver blade through the screen door slider. Kept the actual handle off and tied a wire between two screws to pull it shut. Worked for 10 days until I could get back home and reset it all with some Loctite to keep the screws from getting loose and the mechanism hasn't 'jumped the track since'. This was a 2004 Safari... your mechanism might differ.
Silver.Sanctuary is offline   Reply With Quote
Old 12-24-2015, 05:07 AM   #27
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Jim,
One the positive side of this, at least we know how the emergency exits work. Congrats on your agility, maybe you should have that photo enlarged and framed?
Other than the inconvenience involved, I'm glad that the problem wasn't really that serious...
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Help - MH Brakes Locked Up! swebster Mechanics Corner - Engines, Transmission & More... 99 07-31-2017 05:22 PM
Dog locked inside trailer with the keys! Kristi Foster The Pet Forum 62 10-29-2013 08:32 PM
Door lock appears to be broken and locked from inside too! LucyPepper Doors & Locks 12 10-12-2009 10:20 PM
locked inside.. can't get out greenRNtrav. Doors & Locks 5 08-02-2009 09:51 PM
Locked out of our exterior compartments...no keys Anna Exterior Storage Compartments & Access Doors 12 07-07-2008 10:20 PM
