Originally Posted by harrodone
help : how do you remove front door lock assembly, and interior door handle
There is a small screw at the bottom of the interior handle.
There is also a small screw in the edge of the door.
There are 3 screws on the inside that also must be removed.
Then, a few rivets around the lock, on the inside, must be removed so that the metal can be flexed which allows the lock to be removed.
The handle shaft on the inside, won't go thru the opening, unless that metal is slightly pulled away.
