Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 07-23-2011, 09:21 PM   #1
2008 27' International CCD FB
Lakeway , Texas
Help needed with inside door handle
on the road in durango and the interior door handle is very loose and I'm afraid about to fall off. 2008 International CCD. can't find any posts on how to fix it. thanks, marty
2goldens is offline   Reply With Quote
Old 07-24-2011, 06:28 PM   #2
steel/aluminum fabricator
2004 22' International CCD
Penticton , British Columbia
lol. Dont worry. It will fall off if its anything like the handle on my 04 ccd. Just happened this weekend. What you can do is remove the 3 screws that hold the inside handle on, remove the handle and cover plate. You will see that the handle is basically pressed into the plate on the inside of the cover plate. With a ball pien hammer you can pien over the edges of the inside of the handle. Or.. You can use a 2 1/2 lb axe and an old drill bit . Thats what i used when it happened camping and all i had was a 2 1/2 lb axe and a rusty drill bit.
zedex is offline   Reply With Quote
Old 07-24-2011, 07:59 PM   #3
The wife snapped this whilest i was busy fixing crappy lock.
Its raining inside the AS Snedwid On The Road... 6 06-09-2011 08:51 AM
Dust accumulation inside AC... AIR-Quarius Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-06-2011 05:32 AM
Therapy session needed...No Phd required! Phrunes Trailer Values 22 04-24-2011 07:24 PM
Had the honor to step inside a 1962 Bambi this weekend and fell in LOVE with the heat J5MM LP Gas, Piping, Tanks & Regulators 9 03-14-2011 02:52 PM
