Old 06-15-2012, 06:52 PM   #1
Bootsinister's Avatar
1975 Argosy 22
Murray , UT
Unhappy HELP !! Lost keys..
YES it is sadly true.. My recently purchased 75 Argosy's Keys are gone.. Most likely in the garbage can at the end of the bench.. never to be seen again.. it has spurned quite the spring clean up to no avail ... No big deal though head down to the local locksmith right ?? Wrong.. There were able to get all of the locks going except one.. The Illinois two sided on the thetford fresh water filler door.. any idea if once the lock is drilled will i be able to replace the cylinder or will it require replacing the entire door assembly :-( ... Thank You In Advance THIS forum is the Greatest!!!
BoOt
Bootsinister is offline   Reply With Quote
Old 06-15-2012, 07:02 PM   #2
jimmickle's Avatar
2000 31' Land Yacht
If you have a good Airstream dealer nearby, check with him. he should be able to supply a key. if not, jackson center. since most of the keys are the same, an SOB dealer might have one.
jim
jimmickle is offline   Reply With Quote
Old 06-15-2012, 07:45 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
BoOt
Out of Doors Mart sells that as a WF-01 for $6.95. Local Airstream dealer basically told me I was SOL and offered no suggestions (not even unhelpful ones) but they're not an old dealer so they probably don't care about stocking older parts... I'll remember that if/when I consider a new trailer.
Here's the ODMRV listing for the key.
David
Old 06-15-2012, 08:39 PM   #4
1975 Argosy 22
Murray , UT
AWESOME!! This Forum is amazing !! So Glad I did not Impulsively DRILL !!
Thanks For Your Info!!
