Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 09-13-2009, 02:38 PM   #15
Lumatic's Avatar
Profile:  1971 25' Tradewind
1967 24' Tradewind
Estancia , New Mexico
Wildr
The 1st photo did not show up.
The 1st "tang" should be easily seen on the back of the cylinder. It is round about 1/8" diameter and sticks out about 1/8" It is in line with and right at the end of the key slot on a the diameter and circumference of the circular back of the lock key cylinder. It should be obvious how when the cylinder is turned the tang engages the slot on the shaft.
get off the road hippy
Old 09-13-2009, 03:58 PM   #16
Lumatic's Avatar
1967 24' Tradewind
You should see the tang in this one
door & frame, door latch, door-within-a-door, entrance door repair, lock repair
Door lock key hjlairf 1956 Flying Cloud 8 10-03-2009 12:57 PM
The key broke off in the lock! Relentless Doors & Locks 8 11-29-2008 07:49 AM
Entry door bolt lock with an outside key willyd Doors & Locks 4 06-22-2008 01:07 PM
Missing Key for Potable Water Lock Door Streamer1 Doors & Locks 16 03-25-2007 08:00 PM
$60 to make key for lock inside handle SafeHarbor 1978- 1979 Excella 500 0 04-17-2006 06:30 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
