Old 11-12-2007, 03:28 PM   #1
1998 25' Safari
Cape Cod , Massachusetts
HELP! hinge screws loose
The bottom hinge screws are loose on the entrance door to our '98 safari. They seem to be stripped. Any advice on how to repair this would be much appreciated.
TinZilla is offline   Reply With Quote
Old 11-13-2007, 10:52 AM   #2
If they are the same as in my trailer, the hidden nuts behind the skin are not captive, and they just rotate. (Yes, that is very silly). A couple of solutions can be found here:
http://www.airforums.com/forums/f4/d...mare-2536.html
Doing a search on "hinge" will throw up more reading.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 11-13-2007, 01:20 PM   #3
beaubill57's Avatar
1992 25' Excella
2002 25' Classic
Daphne , Alabama
Door hinges
The door hinges are held on with a bolt and nut,they just look like screws. The nut has backed off the bolt,go to search and you will find several post on fixes for door hinges
beaubill57 is offline   Reply With Quote
Old 11-15-2007, 09:44 AM   #4
1998 25' Safari
Thanks for putting me in the right direction. Bolts floating in the nether regions behind my wall panels. Fun. Fun. At least we know what we are up against.
-Jenn
Old 11-15-2007, 11:54 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before digging into the trailer try this. Put a load, screwdriver wedged between thw trailer body and the hinge, on the bolts by appling pressure against the hinge to put a load on the captive nuts behind the wall and try to tighten them while the hinge is loaded. Alternate between the bolts as you tighten about 1/2 turn per bolt to make sure the load remains on the other bolts. What you are tring to do is cause drag on the nut while tightening the bolts against that drag.
If your lucky the bolts will tighten enough that you can then realy Hog Down on them.
2004 Excursion 4x4
Old 11-16-2007, 09:23 AM   #6
harold1946's Avatar
2005 30' Land Yacht 30 SL
Surprise , Arizona
Howie is right on and couple of drops of blue locktite will prevent them from loosening again. have fun
harold1946 is offline   Reply With Quote
Old 11-16-2007, 09:57 AM   #7
1998 25' Safari
Thanks Guys-
The husband knows what you are saying and is going to try it today. Hope it works!!!!!
- jenn
Old 11-16-2007, 10:12 AM   #8
_
hi tinzilla...
well it won't hurt to try the above...
the proper fix isn't that hard.
it requires drilling out a few rivets on the inner door frame trim and raising the wall covering
then peel back the inner skin over the hinge areas...
then remove the nuts, clean, loctite and secure. additional nut can be added if u like.
another option is to cut a small port hole in the innner skin, over the hinges
again remove, clean, loctite, secure.
then patch inner skin with alum/rivets and glue wall covering back in place.
cheers
2air'
loose wire whistler Electrical - Systems, Generators, Batteries & Solar 6 02-21-2004 03:50 PM
Rivets or screws? TBKP's Overlander Interior Restoration Forum 3 07-25-2003 12:47 PM
How not to loose a hubcap qqq Wheels, Hubs & Bearings 14 03-31-2003 06:37 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
Screws... Chuck Ribs, Skins & Rivets 1 10-21-2002 08:22 AM
