Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Prev Previous Post   Next Post Next
Old 09-08-2009, 10:15 AM   #1
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Help Help Help - Door Lock Issues
I titled this tread this way because it relates to several problems all relating to the door locks.
On our last trip south the trailer door locked just when the grand kids decided they had to stop. At first I thought it was the dead bolt because the spring that positions it had failed some months ago. This failure caused the dead bolt to move from the unlocked to locked position depending on road vibrations. The dead bolt responded to the key but that did not unlock the door. Now what? I got a coat hanger and worked it in through the front window to unlock the window and sent my granddaughter in through the window. She was not able to unlock the door so I went in through the front window and had the same results. Now What? After a bit of thinking I realized I had cut holes over the door hinge bolts some time ago to adjust the door. Time to remove the door. After removing the door I found the tongue on the door latch had broken off and remained in the closed position.
Now I have a door with no latch and a dead bolt I can't trust. Time to drill a hole in the thumb latch on the inside of the dead bolt and hold in in position with a small bungee cord. See below.
Now do I trust just that? I tied the door closed with additional bungees and a strap and headed south.
Now for the HELP.
Anyone know of a source for parts for the door lock used on a 1991 Airstream? The factory says they are no longer available. Also any information on the toggling system of the dead bolt or how to remove the dead bolt and pull handle without removing the interior skin?
Later I may post about the 1/2 gallon of ice cream that was melted on the kitchen floor when we stopped for the the night. the bolt that came out of the couch when we attempted to put the grand kids to bed, the crushed wheel chuck, the welds failing on my arm chair, the tongue box door coming off, and the receiver dropping a chunk of metal.
All in all it was a great trip but I am beginning to think 150,000 plus miles is taking a tool on my trailer.
ID:	86838   Click image for larger version
ID:	86840   Click image for larger version
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Door lock rebel beck Doors & Locks 7 07-16-2008 02:39 PM
Newbie owner of 23' rear door - pulling issues? mendosoft All Argosy Trailers 21 03-29-2008 01:03 AM
66, 67, 68, 69 Door Lock 68 Overlander The Vendor's Forum 6 02-05-2007 11:24 PM
door lock rwilly Doors & Locks 16 09-07-2006 11:16 PM
How to lock the door Dbraw On The Road... 17 05-18-2003 08:05 AM
