Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 08-24-2009, 11:38 PM   #1
Profile:  1970 23' Safari
Flagstaff , Arizona
Help! Exterior door lock removal 1970 Safari
This should be a simple task but I can't remove the exterior door lock due to a bolt/pin that attaches to the interior handle? The interior handle comes off easy with one screw however I can't get the unit to come off without removing this pin?
Arizonachip is offline   Reply With Quote
Old 08-24-2009, 11:44 PM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
Welcome to the forums!
The lock you have was used from 70 to 77, I believe. Removal is fairly simple. You have the interior handle off and the interior locking knob simply unscrews. You then have three screws on the interior side of the door and one screw that is located in the door jam.
BTW, be careful with the lock, it is pricey!
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 08-25-2009, 12:03 AM   #3
Flagstaff , Arizona
Thanks Azflycaster, I just need to put a vice on the pin and it unscrews? There was a small pin next to it that I just had to unscrew however this thing was on pretty tight. Maybe it's not original and the previous owner rigged it? Thanks again!
Old 08-25-2009, 07:10 AM   #4
Phoenix , Arizona
Images: 62
Here are the directions from my service manual. They say to remove some inner rivets and pull back some skin. I did not need to do that. The pin that screws out is #6 in the picture.
ID:	86061   Click image for larger version
Richard
1970-1977 Main Door Lock gvanman Doors & Locks 52 10-17-2008 11:22 AM
Lock for 1970 Overlander Kiah 1970 Overlander 4 08-01-2008 02:18 AM
need door lock (tumbler insert) for '72 safari Jdad Doors & Locks 11 06-12-2006 01:18 PM
Exterior Lock 1967 AS Overlander stonerock Doors & Locks 0 04-04-2005 11:43 AM
Broken Exterior Door Lock fmzjwill Doors & Locks 37 03-28-2004 04:21 PM
