Old 09-24-2008, 07:40 PM   #1
Baltimore , Maryland
got a hole needs filling
There is this gap in my dead bolt. I am very certain that a previous owner replaced the one that was there with this one.
You can see the same gap on the backside of the door too.
This is what the strike looks like. The dead bolt works fine, so this is why I am hesitant to fix it. I see that there is a plastic washer or spacer between the dead bolt and the skin of the door. It is close to the same thickness as the alclad I have. I was thinking of cutting out a ring and putting it where the plastic washer or spacer is. I could then rivet the ring into place and make the nasty looking gap go away. Might even dress it up a bit. Does anyone have any thoughts on this?
Old 09-24-2008, 07:58 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Sounds good to me, or you could just reskin the door
Old 09-24-2008, 07:59 PM   #3
Images: 59
Hmmmmm. . .
Most of these deadbolts have a selectable backset, either 2 3/8" or 2 3/4". It looks like the hole was made for a 2 3/4" backset, but the deadbolt was installed with the 2 3/8" setting.
Something to check before you cut metal.
Old 09-24-2008, 08:08 PM   #4
65CV's Avatar
Western , Massachusetts
Gaps to fill
Frank-
I have the same problem. I didn't plan to get to it until I rebuild the door this winter.
I was planning to use a hole saw to cut two pieces of plywood, then chuck a bit of scrap aluminum between them and turn it to make an oversized washer that looked pretty on the outer edge. I could then drill a not-so-pretty center hole and vulkem it inside the lock, showing only the good parts.
I kinda liked the washer idea rather than extra rivets. If you can't buck, it is just not worth it.
If you want, I'll make an extra 1 or 2 at the same time.
John
65CV is offline   Reply With Quote
Old 09-24-2008, 08:11 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Originally Posted by markdoane View Post
Hmmmmm. . .
Check with a good locksmith. They may have a solution.
Old 09-24-2008, 09:52 PM   #6
Filling hole
A nice bead of Vulkem would take care of that hole.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-24-2008, 10:25 PM   #7
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Lock companies make different size Trim Rings that are used to hide over sized holes. Here is one site that has some. - Locksmith Supplies - Lock, Trim Rings
A good lock shop should have just what you need.
Richard
Old 09-24-2008, 10:54 PM   #8
soldiermedic's Avatar
Florissant , USA
Frank,
I would make a nice round trim plate out of alclad, take the deadbolt out, rivet new beauty ring on, and reinstall the deadbolt.
Simple, elegant, looks better than a bead of sealant.
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 09-25-2008, 12:03 AM   #9
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Two best choices?
Hi, I'm with azflycaster; Buy door lock trim rings. Simple, clean looking, and easy to install. Or go with Aerowood, rebuild the whole door and re-install the correct locks.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 09-25-2008, 03:37 AM   #10
Wow quick responses... thank you fellas.
I hang doors all the time, did a massive front door with $1400 lock set just yesterday. Working in wood and metal are vastly different and require a different process.
I initially thought that the back set was wrong, but it turns out a previous owner used the original parts of the throw bolt and only replaced the dead bolt assembly. I put it back together and left it for another day. I scratched my head and pointed it out at a few rallies to get some feed back.
I secondly thought about using vulkem. I actually got a tube out, rags and WD40 for clean up,... and got ready to caulk the gap. And then it dawned on me that that would look so incredibly non professional. It would be a big gray bead right at eye level. It would look like Uncle Philips bath tub all gooped up with caulk, trying desperately to keep the water from doing what water does. It just was not an option. I stopped and scratched my head some more.
I did not consider re skinning the door. I think it would be a shame to have Anna loose all those deep oxidation pits on the door surface. I polished and sanded and polished some more to make it look good. I even had to come to terms with her skin being "loved by the elements" while polishing that door. I would consider it, but not unless it was really necessary.
Now those beauty rings are the ticket... I think though, the name implies it must be a thing of beauty. I can only see fabricating one from Alclad as an option. Nothing wrong with a ring of rivets around the dead bolt, might even add a level of detail... visual interest. Stay tuned, I will post some photos of what I do. First thing is to buy a new forstner bit 2 1/8" for a perfect center hole.
Old 09-25-2008, 06:54 AM   #11
Florissant , USA
Frank,
You can make your payment for $50 to Steve's Trailer Works for the design idea.
Steve
Old 09-25-2008, 08:26 AM   #12
I think you should make the trim ring (from Alclad of course) using a special shape. A good buddy of mine made me a nice patch in the shape of The Great State Of Texas.
Maybe you could use the shape of Maryland?
Old 09-25-2008, 09:38 AM   #13
Florissant , USA
Marcus,
Do you know how little that would cover, and look really weird at that!
How about the Wheel of Dharma for our Buddhist friend.
Namaste!
Steve
Old 09-25-2008, 09:42 AM   #14
Good idea Steve!
Or how 'bout this one?
Old 09-25-2008, 05:52 PM   #15
Or what about something like this?
Would that work better than a bead of vulkem? See how I did it, in detail, on my blog. Tomorrow I fill the hole on the backside. That will be even more fun than doing the front side.
Old 09-25-2008, 06:03 PM   #16
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
That looks great!!!!!!!!!
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-25-2008, 06:07 PM   #17
1973 25' Tradewind
Romulus , New York
simple and cheap fix
You can buy a stainless trim ring kit designed for a deadbolt installation in a wooden door. It will finish out with a 3/16' reveal. Go to grainger.com to find the one you need
jayray5 is offline   Reply With Quote
Old 09-25-2008, 07:05 PM   #18
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Great job Frank!
J
1956Safari is offline   Reply With Quote
Old 09-25-2008, 07:08 PM   #19
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Frank, A great solution to a pesky issue. Looks great.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-25-2008, 07:09 PM   #20
Alumanutz's Avatar
1966 22' Safari
Chico , California
Nothing like a personal touch. Now when you enter, You will be reaching for the stars!!
By the way, that probably happened because your running gear is unbalanced and your axel is shot.
NUTZ
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is offline   Reply With Quote
Filling tires/nitrogen Gas Phil Gobie Tires 44 04-26-2009 02:31 PM
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
Help with Filling Water Tank james814 Fresh Water Systems 1 07-16-2006 09:13 AM
Water Tank filling up thecatsandi 2006 - 2010 Classic (all lengths) 11 05-13-2006 07:14 PM
Fuel Filling Problem Chaplain Kent Mechanics Corner - Engines, Transmission & More... 7 07-15-2005 12:21 PM
