Old 09-25-2008, 05:52 PM   #15
Baltimore , Maryland
Or what about something like this?
Would that work better than a bead of vulkem? See how I did it, in detail, on my blog. Tomorrow I fill the hole on the backside. That will be even more fun than doing the front side.
Old 09-25-2008, 06:03 PM   #16
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
That looks great!!!!!!!!!
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-25-2008, 06:07 PM   #17
1973 25' Tradewind
Romulus , New York
simple and cheap fix
You can buy a stainless trim ring kit designed for a deadbolt installation in a wooden door. It will finish out with a 3/16' reveal. Go to grainger.com to find the one you need
jayray5 is offline   Reply With Quote
Old 09-25-2008, 07:05 PM   #18
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Great job Frank!
J
1956Safari is offline   Reply With Quote
Old 09-25-2008, 07:08 PM   #19
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Frank, A great solution to a pesky issue. Looks great.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-25-2008, 07:09 PM   #20
Alumanutz's Avatar
1966 22' Safari
Chico , California
Nothing like a personal touch. Now when you enter, You will be reaching for the stars!!
By the way, that probably happened because your running gear is unbalanced and your axel is shot.
NUTZ
View my Airstream Blog at www.alumanutz.blogspot.com
Grown men, dressed as clowns, concern me.
Alumanutz is offline   Reply With Quote
Old 09-25-2008, 07:21 PM   #21
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
No, no, no!!!
I think the Vulkem is the best idea... and easiest. now, you have 4 more holes in the trailer.. .better get that running gear balanced.
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 09-25-2008, 07:26 PM   #22
I am getting new axles soon. Are they available pre balanced? Does drilling the holes throw the balance off?
Old 09-25-2008, 07:55 PM   #23
Alumanutz's Avatar
1966 22' Safari
Chico , California
I'm so confused. Rob sees four holes but i see five. I need another beer!
NUTZ
Old 09-25-2008, 07:58 PM   #24
robandzoe's Avatar
Plymouth , New York
ok, 5
I just got back from having one too many Yuengling
Plymouth, NY 13832
Courtesy parking
Old 09-25-2008, 08:06 PM   #25
soldiermedic's Avatar
Florissant , USA
It's actually six new holes...the dead bolt goes through the 6th.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 09-25-2008, 08:39 PM   #26
Alumanutz's Avatar
1966 22' Safari
Chico , California
I've tried having too many, but I always pass out before I get there!
NUTZ
Old 09-26-2008, 06:58 AM   #27
robandzoe's Avatar
Plymouth , New York
yes, but....
That hole was already existing....it is 5 new ones.... I like the personal touch Frank.... you come up with the coolest ideas...
Plymouth, NY 13832
Courtesy parking
Old 09-26-2008, 08:07 AM   #28
NoMoSOBs's Avatar
1998 30' Excella 1000
Aylett , Virginia
Images: 14
Not quite what I was expecting when I clicked on this thread, but I actually have a similar problem. I don't think anyone was locked out, I believe your trailer had a "travel latch" on the door, which is just a non-lockable knob on both sides. Mine has one that doesn't work (no doubt because my axles are shot ), and I've been looking for a deadbolt to replace it with. Unfortunately I can't find one that has the right backset and thickness, and because I DON'T want to drill that hole, I'm just living with it for the time being. Nice job on the star though!
Hey Frank, a question- where is the battery on your trailer? Mine has the same funky little compartment up front that is about 4.5" wide and aside from maybe a motorcycle battery, nothing fits the darn thing. Did you find something to fit or did you relocate yours?
NoMoSOBs is offline   Reply With Quote
Filling tires/nitrogen Gas Phil Gobie Tires 44 04-26-2009 02:31 PM
Filling freshwater tank, newcomer needs help! thundercakes Fresh Water Systems 1 09-13-2006 09:05 PM
Help with Filling Water Tank james814 Fresh Water Systems 1 07-16-2006 09:13 AM
Water Tank filling up thecatsandi 2006 - 2010 Classic (all lengths) 11 05-13-2006 07:14 PM
Fuel Filling Problem Chaplain Kent Mechanics Corner - Engines, Transmission & More... 7 07-15-2005 12:21 PM
