Could someone photograph their 1963 Overlander Door-within-a-door gasket set up? Previous owner did some wacky things. Vintage trailer has some specific 1963 gaskets. Picture speaks a thousand words... thanks!
I use 3/8" d seal for both the inner and outer door gaskets. Put it on the door in a door itself, not the outer door. You can also use the same d seal for the main door, mounted the same way.
