Old 01-30-2010, 08:10 AM   #1
1995 25' Excella
Spring , Texas
Frustrating door leaks
Been trying to eliminate a leak at the hinge side of the door. Bottom part of the door under the lower hinge was not flush, repaired that and did the dollar bill test. It is good all the way around. There are no leaks above the door frame. What I can't understand is how water can get over the lip of the door frame? The door frame all the way around has a lip of probably 1/2" on the inside.
BayouFishin is offline   Reply With Quote
Old 02-11-2010, 12:13 PM   #2
connorsa's Avatar
1999 34' Excella
Durango , Colorado
Did you ever solve your leak location issue?
Home is where you park it.
Anne
connorsa is offline   Reply With Quote
Frustrating leak from Fantastic Fan alteration AirHeadsRus Leaks - Weatherstrips, Gaskets, Caulks & Sealants 13 11-25-2009 03:36 PM
Door leaks Norm1234 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-08-2009 06:34 PM
Leaks around the door sdiddy Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-22-2007 04:04 PM
Leaks Sundance Sinks, Showers & Toilets 4 07-03-2007 02:47 AM
Helpful feature is frustrating pamelake Forum Admin, News and Member Account Info 9 03-13-2006 11:03 AM
