Old 05-30-2016, 06:25 PM   #1
Dan S's Avatar
1975 Argosy 26
Normandy Park , Washington
'Fridge panel access key
Are all/ most keys servicing the outside access panels similar?
I have a '75 Argosy and can't locate the refridge key to service the unit. Hoping to copy someone's key in Seattle if it's doable?
Thx
Dan
206-383-4401
Dan S is offline   Reply With Quote
Old 05-30-2016, 06:30 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Thx
Dan
206-383-4401
It should be one of the Chicago Lock compartment keys.
Old 05-30-2016, 06:34 PM   #3
Dan S's Avatar
1975 Argosy 26
Overlander, are you implying I can obtain one from them?
Old 05-30-2016, 06:47 PM   #4
Well Preserved
1993 21' Sovereign
If you don't have one, you should be able to simply order a replacement from your friendly Airstream dealer. To the best of my knowledge, the PO of my trailer is the only one that rekeyed all my locks to something other than standard.
Old 06-01-2016, 08:04 AM   #5
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
On my Tradewind, the fridge and battery door keys are the same but the water fill door is different. All Airstreams of a similar year have the same keys. They are available at any Airstream parts dealer.
terrencecolp is offline   Reply With Quote
Old 06-01-2016, 08:29 AM   #6
1978 Argosy Minuet 6.7 Metre
Skamokawa , Washington
I have a full set of keys for 78 Argosy Minuet. I can't check the fridge lock since it's gone but the battery key worked. I'm in Skamokawa, Wa. if you figure out they will work.
sherry23bee is offline   Reply With Quote
Key for water fill panel W.V. Stream Doors & Locks 3 08-24-2011 08:19 PM
Key to battery access BessieB Batteries, Univolts, Converters & Inverters 8 09-02-2010 05:03 PM
Can i get keys for access panel locks that have numbers dufrain Exterior Storage Compartments & Access Doors 3 01-16-2004 05:18 PM
door and access panel locks BURNZEE Doors & Locks 3 10-30-2003 07:00 PM
