Old 05-04-2011, 09:36 PM   #1
1974 29' Ambassador
coeurdalene , Idaho
Images: 12
Fresh water lock help?
AS came w no keys. Was able to get keys made for all but water fill door. Got two dif keys from airstream dealer. None worked. Any ideas?
adamgraves is offline   Reply With Quote
Old 05-04-2011, 09:43 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have had the same problem trying to get a second set of keys for my trailer. The double edged water door is the only key that I do not have a duplicate for.
Richard
Old 05-04-2011, 09:59 PM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Key
I have a '74 Argosy, it has a water door that is sort of like a funnel when you open it. The number on the key is 87 and it is not a double edged key. Hope this helps.
Old 05-04-2011, 10:17 PM   #4
1985 31' Excella
Fresno , Texas
I called Airstream and they sent me keys out for an '85 The key is a DECO 1 and it is a stamped key with the notches on one side. Seems like my '79 may have had double sided key. A good locksmith can also make it. I was also told that you can sometimes use a screwdriver and turn it. Turn it counter clockwise so you are loosening and not tightening the nut.
Wsmith is offline   Reply With Quote
Old 05-04-2011, 10:27 PM   #5
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
This is timely... the PO of my Argosy never had the key for the fresh-water fill, and he said he just always stayed where there was a water hookup and they carried bottled water to drink anyway.
I'm planning to have a locksmith take a look at it. One thing that complicates mine is that some yoyo (apparently at the factory in '75!) riveted the front data plate with its edge across the edge of the lock cylinder. It might be a pain if the lock cylinder has to come out.
— David
Old 06-24-2011, 04:40 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Ah the joys of having unusual things.
The lock for the '70s Thetford fresh-water fill door on most Airstream and Argosy trailers is apparently a "Double-sided Illinois H keyway" lock. This is not a common lock, and the locksmith I went to doesn't have any key blanks or "tryout keys" for that keyway. (I chose this one because it's an established business and was between the storage facility and the house.)
At least they gave me all the info they could about the lock, charged me nothing for their efforts and recommended a couple of other places to call.
Out of Doors Mart apparently sometimes sells the key, but it's out of stock at the moment.
Water Fill Key WF-01 - $6.95 : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
I'll be watching that if I don't find the key another way.
For '74 Airstreams, the Mother Ship lists "G248" as the water-fill key, and that's an Illinois double-sided key so I'm going to give my local dealer a call on Monday and try to get one of those (of course I found that info JUST after 5 today... *sigh*
The final fall-back position is to buy a bunch of them from this place, they'll cut Illinois keys by key-code but they have a minimum $25 order, so I may have a couple of spares soon.
— David
Old 06-24-2011, 05:10 PM   #7
If the door is plastic, allow it to heat up in the sun.
Or, heat it with a hair drier, to about 130 degrees, NO MORE.
Then with a butter knife, you can flex the door enough to open, by placing the knife blade at the door opening side, and giving the knife a little twist.
Old 07-05-2011, 02:39 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
Out of Doors Mart has the G248 key in stock again, if that's the one you need. I've already ordered mine!
— David
Old 07-30-2011, 06:58 PM   #9
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
While I was trying to locate a locksmith with easy access (I live in the sticks so it is cheaper if I go to them.) I ordered a "beginners" lock picking kit from the web. I figured the cam locks on the panel doors couldn't have more than 3 or 4 barrels, should be easy to pick. $28 later and about 3 minutes of labor and maybe 2 hours of research... water hatch is opened and lock is replaced with a lock keyed the same as the battery door. DIY!!! BTW, I am a boat captain and know nothing of locks and the replacements were found at Home Depot.
captmatt is offline   Reply With Quote
Old 07-30-2011, 07:01 PM   #10
captmatt's Avatar
1986 31' Sovereign
Naples , Florida
Oh... double sided lock, well I didn't have that to deal with, good luck!
Old 07-30-2011, 07:06 PM   #11
DKB_SATX's Avatar
1976 Argosy 28
The G248 key was right for mine, so now I have a pair of keys.
— David
Old 12-28-2011, 09:13 PM   #12
Antipode's Avatar
1975 Argosy 28
Spicewood , Texas
Water door and others
'75 28' Argosy needed single sided, Taylor Y11 fit and I cut it with jewelry files, original was missing. Problem was lock barrel is in the trailer not the door and I didn't want to pull side walls above the fill tube to change that one.
I changed the other three doors with same key set and length locks as originals but there's about a 1/4 inch play in master and fridge doors except battery door. I even inverted the offset bended pawl. Where did the extra space come from? Any suggestions on a filler between the door lip and new pawl?
Thanks.
Work Camping, Reno is $4,100 and climbing.
Antipode is offline   Reply With Quote
Old 12-28-2011, 10:40 PM   #13
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The doors on my trailer were lose when locked. The gaskets looked good so I riveted a 1/8"x 1/2" piece of Aluminum flat stock on the inside of the opening in the area where the pawl makes contact. I made the piece long enough so when I riveted it in the pawl would not contact the rivets. Now I must put slight pressure on the door to lock and unlock it. My concern was losing a door going down the road along with heat lose in cooler weather. Now they are nice and snug in the openings.
Old 12-29-2011, 04:45 AM   #14
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Sounds like Andy may have had the nickname "fingers" in a prior life
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
fresh water tank-drain or not? AUTAILGATER Fresh Water Systems 15 05-21-2012 09:44 AM
Fresh water tanks leaks fixed! chiefneon Fresh Water Systems 1 07-31-2011 07:02 PM
Grey Water Tank Flushes Toilet (to conserve fresh water) LittleRadio Sinks, Showers & Toilets 8 03-28-2011 10:10 AM
1975 tradewinds fresh water tank elkay12 1970-79 Tradewind 2 03-25-2011 08:23 AM
