Old 02-17-2016, 09:52 PM   #1
1970 23' Safari
Elkhart , Indiana
Thumbs up Fixing broke set screw and inside lock on 1970 safari
So I found my inside lock was seized. Hit it with silicon spray. Used a hammer and finally got it moving up and down freely.
Well I need a key made so I called some locksmiths and was told it would be 100-150 to come fix it. Or take it off and bring it in for 20. The 4 screws came out fine. The set screw was busted off at the bottom. I had to drill it out. Didn't realize the set screw goes all the way to the top of the handle. I re drilled it and tapped it out. And used a 3/4 stainless steel screw to replace the set screw. It works great. I hope this helps someone else some day!
Thill_1985 is offline   Reply With Quote
Old 02-17-2016, 09:57 PM   #2
1970 23' Safari
Elkhart , Indiana
Other side
Also I only removed 4 pop rivets from door skin to get handle off
Approaches for fixing stripped screw holes in closet bonginator General Interior Topics 10 06-30-2012 09:28 PM
where is the hinge pin set screw? D/S I Doors & Locks 5 03-29-2009 11:09 PM
Hitch Set Screw, or is the winter just getting too long? SteveH Hitches, Couplers & Balls 42 03-01-2009 03:13 PM
set screw on power jack mj81excella Jacks, Stabilizers, Lifting and Leveling 8 05-26-2008 08:59 AM
Frozen set screw guy99 General Motorhome Topics 2 06-15-2005 08:28 PM
