Old 10-19-2002, 12:43 PM   #1
Excella3287's Avatar
Question External door handle
Looking for directions in removing door handle on 87 excella. Wanting to replace with newer version or polish. Also having troulble with folding step not locking in place. Can you just grind away at interior slide to fix?
Excella3287 is offline   Reply With Quote
Old 11-09-2012, 11:35 AM   #2
xitjustice's Avatar
1994 28' Excella
Clearwater , Florida
I just changed the exterior door handle. I had to unscrew it near the striker plate (2), and unscrew the inner handle. That's basically it.
The folding step... Mine was acting really goofy. I found a bunch of loose allen key bolts on it. Also some lube would probably be in order. Might want to try and watch the metal guides as it slides (or doesn't slide) back into place.
xitjustice is offline   Reply With Quote
Old 11-09-2012, 04:47 PM   #3
1981 31' Excella II
New Market , Alabama
What are you calling the handle. A photo would help. My trailer has a latch handle on the door and a grab handle to the right of the door with a dead bolt in it.
Perry
External charger and battery ? Rousseau Batteries, Univolts, Converters & Inverters 5 09-01-2011 12:55 AM
External Fresh Water filler spout pickerdd Fresh Water Systems 3 08-31-2011 01:56 PM
'04 Safari- what does the external cable connection energize? DJW Audio, Video & TV 0 06-02-2011 08:35 AM
Int'l Bambi 19' External Propane Connection? jambie 2005 and newer - Bambi all models 1 03-06-2011 07:28 PM
Original External Water Tank fill cap for 69 commander31 Fresh Water Systems 1 02-07-2011 01:38 PM
