Old 04-11-2010, 09:17 AM   #1
1976 Argosy 24
Savannah , Texas
Exterior door latch needed
I just purchased a '76 Argosy and the latch that holds the door open is broken (the piece that attaches to the door). I can't find anything online just yet though I did see a similar post that suggested a link but they don't carry the Bargman door latches which is what I was told this piece is called.
If anyone can point me in the right direction I would truly appreciate it.
TKS
DavidMc56 is offline   Reply With Quote
Old 04-11-2010, 09:23 AM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
If it the same as my Overlanders,Vintage Trailer Supply carries it. A picture would help. Dave
easyride is offline   Reply With Quote
Old 04-11-2010, 10:00 AM   #3
1980 31' Excella II
Drummond Island , Michigan
If this is the piece that holds the door open so that it will not swing back to close it is called and "outside main door hold back". It is made up of four pieces not counting the pop rivets. I beleive you want the little catch that is attached to the door itself by two pop rivets. The other pieces attach to the body of the trailer outside and consist of a plastic spring loader plunger and an aluminum shell the plunger slides back and forth in mounted on a plastic base. You can order each piece separately and they are not expensive. www.odmrv.com carries them. I know becuase I have a new one on the way right now because a gust of wind caught the door and slammed it against the latch hard enough to snap the tapered part off the sliding plunger. If I were you I would order one of those as well to have on hand along with the door catch portion. This is the second time I had to replace the thing for the same reason.
Ahzmyrah is offline   Reply With Quote
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
1975 Argosy MH Overhead Cabinet Latch Info Needed 911rs Argosy Motorhomes 1 06-30-2009 10:05 AM
Main door latch needed '69/'70 tradewind Eliminator46 1970-79 Tradewind 6 10-11-2008 05:19 AM
Vintage Airstream window latch TOOL NEEDED 1956Safari Windows & Screens 6 06-29-2007 12:45 PM
Exterior advice needed brenda02 Clearcoat, Exterior Paint & Trim 6 03-06-2007 09:31 AM
