Old 01-15-2003, 04:28 PM   #15
Finally Retired
Picts
Here is the finished product and it works great
Dave and Louise
#2852
Finally Retired
LKappenman is offline   Reply With Quote
Old 01-15-2003, 04:29 PM   #16
Finally Retired
pict 2
pict. 2
Dave and Louise
#2852
Finally Retired
Old 01-15-2003, 04:30 PM   #17
Finally Retired
pict 3
Dave and Louise
#2852
Finally Retired
Old 01-15-2003, 04:32 PM   #18
Finally Retired
Now we just need to cover the new bolts with something it just had some foam stuff on it sure is amazing how good the door works.
Dave and Louise
#2852
Finally Retired
Old 01-15-2003, 06:49 PM   #19
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Thanks for the Pictures. Now for the $64.00 question. Did you get Louise help you to lift the door?
I will have to try this as I think there was some type of bushing there from the factory.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-15-2003, 07:20 PM   #20
Finally Retired
You Betch a
She held the door from the outside and turned the allen wrench while I manouvered the nut. It was a dual and successful effort.
Dave and Louise
#2852
Finally Retired
Old 01-16-2003, 06:02 AM   #21
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
After seeing your pictures last night I went out and looked at my hinges. There was something there but I am metal on metal now. I assume those are just a generic nylon washer that you got at Home Depot or Lowes? Do you remeber the size? I see the modification you did, but I would like them to fit like yours do.
You said you loosened and tightened the alllen bolts. Was this to also lift the door, or were yours loose?
Brett G
Old 01-16-2003, 11:26 AM   #22
Finally Retired
We replaced the old bolts that held the hinges to the coach/door frame. (what a job) Yes they are just standard washers with a 1/4 in inside diameter. We had to grind the out side diameter down by putting the correct sized metal washer on a 1/4 in bolt and then put 6 0r 8 nylon washers on the bolt and tighten them with a nut. We then secured the bolt in a drill motor and ground them down to the size of the metal washer using a grinder, you could use a file also or even a sanding block. When installing you might want to offset the notch/slot just an Idea. Let me know if I can be of anymore help
Dave
Dave and Louise
#2852
Finally Retired
Old 01-23-2003, 05:06 PM   #23
Finally Retired
Trip
Went to the ocean on the Oregon coast this past weekend it was very nice the door worked great only had to remember I don't have to slam it.
Dave and Louise
#2852
Finally Retired
Old 01-23-2003, 05:09 PM   #24
Finally Retired
The wheels are usually shiney but with the rain and stuff it needs to have a real good bath. She is almost always looking good
Dave and Louise
#2852
Finally Retired
Old 01-23-2003, 08:49 PM   #25
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
good deal on the hing mods. havent got my new hinges installed it has been too cold. it is supposed to warm up this weekend and i will be helping my friend who has the door off and laid out . i have custom cabinets that were a lot of grief to get removed, they were in the way . so we should have the silver weeinie back together by saturday eve. i am going to take pictures of the job showing the work that has to be done to change out hinges . and ill post those next week. the special bo;ts on the door striker we are going to rotate 180 degrees so the worn spots are on the bottom. im told that the bolts are double nutted inside the jam . shouldnt be a big deal just time consuming to take care of that problem.
al
wb13798 is offline   Reply With Quote
Old 11-09-2012, 11:30 AM   #26
xitjustice's Avatar
1994 28' Excella
Clearwater , Florida
any trick?
Is there any trick to lifting the door in order to get the nylon washers in? I sprayed some silicon on the pin and tried lifting myself. It wouldn't budge. I like the idea for decreasing the outside diameter of the nylon washers with the bolt... I was just wondering how I was going to do that.
xitjustice is offline   Reply With Quote
