Old 12-12-2014, 03:03 PM   #1
2008 19' International
Coupeville , Washington
Exterior door hinge pin
I just noticed that my exterior door, top hinge pin is sticking up approx. 1/2" (and it's splined). Any ideas on the best way to proceed to get it reseated? I started tapping on it (gently) and felt immediate resistance.
My airstream is a '08 International, 19'.
portageking is offline   Reply With Quote
Old 12-12-2014, 03:31 PM   #2
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Use flat tip punch and tap it back down until it is just below the surface (1/8 of a inch).
This is normally due to rough road travel,pulling it with a hd tow vehicle or out of balance running gear on the trailer.
Old 12-12-2014, 03:35 PM   #3
So it's ok to hammer that splined pin back in (with a punch)?
Old 12-12-2014, 05:15 PM   #4
2007 22' International CCD
I'd place a piece of plywood strategically to protect the AS skin as you bang it in. That's how the dealer fixed ours. Just be careful.
KE4GNK/AE
Old 12-13-2014, 01:48 PM   #5
greenflag's Avatar
2016 30' International
Quartz Hill , California
I had the same problem with my 07 25 footer.
I used a rubber mallet to hammer it back in place.
greenflag is offline   Reply With Quote
Old 12-13-2014, 03:39 PM   #6
dznf0g's Avatar
Oswego , Illinois
Do a search on "HINGE PIN" and you'll get lots of info, including a replacement pin with "E-clip" retainers. Just driving it down will guarantee it happening again. You can stake it in place, but it was ineffective for me.
-Rich-
Old 12-13-2014, 04:20 PM   #7
eheffa's Avatar
2008 25' Safari FB SE
Victoria , BC
Or just poor design...
-evan
eheffa is offline   Reply With Quote
Old 12-13-2014, 04:29 PM   #8
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
-evan
And redesigned. Get a set of new style hinge pins with the slot and keeper ring.
Doug and Cheryl
Old 12-13-2014, 06:47 PM   #9
Thanks, and that's what I'm doing - new pins with the retainers.
Old 12-13-2014, 10:44 PM   #10
jfowler218's Avatar
2007 31' Classic
Bend , Oregon
After tapping the hinge pin down on my 06 Classic about twenty times I took it to Rod at C&J Trailer in LA. He tapped it down again then drilled th door hinge and pin. Installed a river and it has been food for two years.
jfowler218 is offline   Reply With Quote
Old 12-14-2014, 08:03 AM   #11
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Staked & secured with red Loctite when the hinge was re-finished 7yrs ago.
Old 12-14-2014, 08:12 AM   #12
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Mine was staked the same way Bob's are when I bought our trailer - used - about 7 years ago. We have towed it over 30,000 miles since then, and the pins have never moved.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-14-2014, 10:04 AM   #13
Moflash's Avatar
Drove mine down and staked and the problem never arose again.
Old 12-14-2014, 11:19 AM   #14
dznf0g's Avatar
Oswego , Illinois
Mine was apparently (bottom hinge only) rotating with the door and wollered out the body half of the hinge where the grip is at the top of the pin . Driving back down, staking AND loctiting, was ineffective. On this application, as well as automotive "exposed" hinges (vans), I am a big believer in full floating hinge pins with mechanical retainers. I only replaced the bottom one on the AS, as the top one is still fine...but the second "e-clip" pin is in my travel parts bag.
I also got a supply of 1/4" e-clips to better support, and adjust the height of, the door. As built, only one hinge was supporting the full weight of the door. By using the e-clips as spacers, door height and more equal load bearing is achieved.
-Rich-
Door Hinge Pin Comes out 64Vette Doors & Locks 26 09-27-2007 05:34 PM
Door hinge pin? 65 overlander Doors & Locks 3 09-10-2005 02:04 AM
Top door hinge pin works out during travel? Kistler Our Community 4 06-20-2005 08:04 PM
door hinge worn not the pin silver 67 Doors & Locks 5 08-11-2004 09:30 PM
Door hinge pin. wyhjr Doors & Locks 3 10-20-2002 04:36 PM
